Now fuel pump has been thrown in too I'm confused argh :-/
You can feel it go flat up at the top of the revs tbh
Ben
Ben
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
I wonder if its a fuel pump getting tired?Certainly has enough fuel down low to give a remap level of torque (just shy of 270lbft), just not enough at the top end for the power. ECU possibly trying to add more fuel but can't, and hence shuts the throttle body itself.
Group A: 002 Group B: 115 Group C: 118
RPM Load Inj. On Time Mass Flow RPM Load Absolute Pres. Absolute Pres. RPM Temperature Load Absolute Pres.
TIME TIME TIME
STAMP /min % ms g/s STAMP /min % mbar mbar STAMP /min °C % mbar
0.01 2680 37.6 4.42 21.47 0.42 2720 63.9 1640 970 0.82 2800 30 100 1120
1.22 2920 109 11.9 69.64 1.62 3040 128.6 2180 1580 2.02 3240 26 100 1890
2.53 3520 188 22.1 138.36 2.93 3800 191.7 2320 2490 3.42 4240 24 87.5 2460
3.82 4760 191 21.76 168.58 4.22 5120 182.7 2370 2210 4.64 5400 24 100 2140
5.04 5440 177.4 20.74 180.56 5.44 5440 174.4 2350 2110 5.93 5440 26 100 2120
6.33 5440 172.9 20.06 178.44 6.75 5520 172.2 2190 2110 7.17 5680 28 94.1 2080
7.65 5880 164.7 19.04 185.69 8.16 6040 152.6 1910 2090 8.65 6200 30 73.7 1970
9.05 6280 151.1 17 165.75 9.47 6360 133.1 1770 1670 9.87 6480 32 71.4 1630
10.37 6600 131.6 15.64 168.83 10.78 6680 120.3 1670 1740 11.2 6760 33 60 1590
11.68 6840 126.3 13.6 156.67 12.08 6840 85 1150 1710 12.48 6840 33 0 1230
12.88 6400 14.3 1.7 9.89 13.28 5760 15 980 1100 13.79 5080 33 0 1050
14.19 4840 12 0 10.58 14.59 4640 12 980 1010 14.99 4440 33 0 1010
Which block do you log for lambda readings? Could see if the mixture was going lean.
Depends how much it closes the throttle, you don't need to be WOT to accelerateNo idea which block covers the throttle position, would be interesting to see it though.
Ahh I c what you mean yeah. Okay I will log them tonight and see what it comes up with Shal I log all 3 together or seperate?
Cheers Ben
Lambdas on block 031, yeah probably worth checking those too, the ones I listed give air mass, timing retard and exhaust gas temps - was thinking possible high EGTs causing fuel dump.
Throttle angle is on 003 (amongst others), actually so yeah - psjunkie, make that 003, 020 and 112.
Wednesday 12 October 2011 18:16:47
1ML 906 032 A 1.8l R4/5VT 0001
Group A: 003 Group B: 031 Group C: Not Running
RPM Mass Flow Load Ign. Timing Lambda Factor Lambda Factor Bin. Bits Bin. Bits
TIME TIME TIME
Marker STAMP /min g/s % °BTDC STAMP STAMP
0.42 1960 11.72 7.8 30.8 0 0.99 1
1.25 2000 13.33 8.6 32.3 0.81 1.03 1
2.11 2040 32.72 82.7 18.8 1.71 1.02 1
3.02 2280 47.81 94.9 15 2.62 1 0.96
3.82 2520 62.44 99.6 9 3.42 0.95 0.95
4.73 2880 93.75 100 9.8 4.24 0.96 0.95
5.53 3280 138.56 99.6 3.8 5.13 0.95 0.95
6.35 3840 151.03 100 6 5.93 0.91 0.95
7.24 4320 157.08 100 10.5 6.85 0.96 0.95
8.04 4720 166.11 100 6 7.64 0.95 0.95
8.86 5080 177.22 100 5.3 8.46 0.95 0.95
9.66 5400 180.86 100 7.5 9.26 0.95 0.95
10.46 5840 183.61 100 6.8 10.06 0.94 0.95
11.28 6000 185.14 97.3 10.5 10.86 0.95 0.95
12.17 6320 185.75 98.8 13.5 11.77 0.94 0.95
13.08 6600 171.11 52.2 12.8 12.68 0.95 0.95
13.9 6760 155.19 98.4 19.5 13.5 0.97 0.95
14.8 6840 73.75 27.5 18.8 14.4 0.84 0.95
15.61 6680 15.44 10.2 9 15.2 0.84 0.96
16.51 6320 13.89 9.8 9 16.09 1.99 1.05
Wednesday 12 October 2011 18:18:24
Group A: 020 Group B: 112 Group C: Not Running
Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization Temperature Load Bin. Bits Bin. Bits
TIME TIME TIME
Marker STAMP CF CF CF CF STAMP °C % STAMP
0.01 0 0 0 0 0.4 30 0
0.8 0 0 0 0 1.2 30 0
1.61 0 0 0 0 2.01 30 0
2.41 0 0 0 0 2.81 30 0
3.21 0 0 0 0 3.61 30 0
4.01 0 0 0 0 4.43 30 0
4.93 3 3 0 3 5.33 30 0
5.84 3 3 3 6 6.33 30 0
6.73 3 3 6 6 7.13 30 0
7.55 3 6 6 5.3 8.04 30 0
8.56 5.3 6 5.3 5.3 8.96 30 0
9.45 5.3 5.3 5.3 8.3 9.85 30 0
10.27 5.3 5.3 8.3 8.3 10.76 30 0
11.16 5.3 5.3 8.3 8.3 11.56 30 0
Those fuelling figures can't be right, it's way to lean under load, hence the knock and the ECU cutting boost etc... closing the throttle.
Any idea why?
fuel request is asking for factory fueling...
boost is higher ~(not that high but higher than stock) but no changes have been made to the fueling
