yes
a shyte map
fuel request is asking for factory fueling...
boost is higher ~(not that high but higher than stock) but no changes have been made to the fueling
see it frequently on "unkown/cheap" maps, and occasionally from named maps too
egt makes no sense... not reading does'nt make sense.. its not 30'c
this will cause issues also, but is another fault, not the main fault imho
Bill the Egt sensor hasn't been screwed into the turbo that has been replaced at sone point in the past I'm gonna have a go at getting the hung removed and it properly put in. As for the shyt map thanks to everybody for looking and getting to the bottom of the problem, looks like a trip to revo now then :-/
So after installing the Egt and new map loaded I should all be good?
Regards Ben
