Hi,
I'm posting these on behalf of a friend - we recently attended a Rolling Road day, however, my LCR hit 267bhp whilst his hit around 240bhp - both remapped (His Revo's and mine Custom code), both with aftermarket induction kits, mine with standard exhaust and his aftermarket.
Would it be possible to check the logs below to see if there's any particular issues at all which could cause a low figure or is it, as the operator said, likely to be due to charge temperatures on the rolling road?
Many thanks guys!
Code:
Group A: '031 Group B: '118
Lambda Factor Lambda Factor Bin. Bits Bin. Bits RPM Temperature Load Absolute Pres.
TIME TIME
STAMP STAMP /min °C % mbar
10.27 1.008 1 10.75 1640 34 0 1020
11.17 1.008 1 11.57 1680 34 0 1020
11.98 0.945 1 12.48 1760 34 0 1040
12.97 0.906 1 13.49 2000 32 100 1190
13.89 1.008 1 14.29 2280 30 100 1390
14.69 0.977 0.961 15.09 2640 29 100 1730
15.5 0.961 0.945 15.9 3080 28 87.5 2350
16.3 0.953 0.93 16.8 3640 27 83.1 2410
17.2 0.891 0.891 17.61 4120 27 83.9 2390
18.01 0.86 0.875 18.41 4600 29 85.5 2350
18.91 0.867 0.875 19.33 5080 30 89 2280
19.73 0.875 0.875 20.22 5520 32 91.4 2190
20.62 0.86 0.875 21.02 5880 33 88.6 2160
21.44 0.883 0.875 21.84 6160 35 88.6 2190
22.33 0.836 0.836 22.73 6480 36 91.8 2080
23.15 0.789 0.782 23.55 6720 38 94.9 2140
23.95 0.75 0.719 24.46 6960 39 99.2 2070
24.96 0.75 0.743 25.45 7200 42 91.8 2020
25.85 0.782 0.774 26.27 7240 42 0 1850
Code:
Group A: '032 Group B: '003
Lambda Lambda Bin. Bits Bin. Bits RPM Mass Flow Load Ign. Timing
TIME TIME
STAMP % % STAMP /min g/s % °BTDC
6.03 0.4 -12.5 5.53 1720 32.28 77.6 17.3
6.83 0.4 -12.5 6.43 2000 43.5 89.8 17.3
7.65 0.4 -12.5 7.23 2320 60.61 96.1 15.8
8.65 0.4 -12.5 8.14 2800 95.83 100 9
9.55 0.4 -12.5 9.15 3440 126.19 100 4.5
10.37 0.4 -12.5 9.95 3960 153.17 100 4.5
11.26 0.4 -12.5 10.86 4520 165.69 99.6 9.8
12.17 0.4 -12.5 11.66 5000 186.72 100 8.3
12.97 0.4 -12.5 12.57 5480 199.69 100 9
13.77 0.4 -12.5 13.37 5880 204.61 100 11.3
14.59 0.4 -12.5 14.17 6240 205.92 99.6 12
15.39 0.4 -12.5 14.99 6560 206.25 99.6 12.8
16.29 0.4 -12.5 15.8 6840 204.19 100 16.5
17.1 0.4 -11.7 16.7 7120 208.72 99.6 18
17.92 0.4 -12.5 17.5 7280 88.28 25.5 21
Code:
Group A: '115 Group B: '020
RPM Load Absolute Pres. Absolute Pres. Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
TIME TIME
STAMP /min % mbar mbar STAMP CF CF CF CF
5.44 1520 26.3 1000 1040 5.02 0 0 0 0
6.32 1520 40.6 1000 1020 5.92 0 0 0 0
7.23 1560 51.9 1000 1040 6.73 1.5 0 0 0
8.14 1640 49.6 1000 1040 7.63 0.8 0 0 0
8.96 1680 53.4 1000 1050 8.54 0 0 0 0
9.85 1840 88.7 1810 1110 9.44 0 0 0 0
10.65 2080 103.8 1990 1260 10.25 0 0 0 0
11.47 2360 123.3 2180 1480 11.07 0 0 0 0
12.27 2760 160.2 2230 1870 11.87 0 0 0 0
13.18 3320 191.7 2360 2390 12.76 0 0 0 0
13.98 3800 191.7 2380 2370 13.58 0 0 0 0
14.88 4360 191.7 2360 2360 14.48 0 0 0 0
15.79 4840 191.7 2320 2260 15.29 0 0 0 0
16.59 5240 191.7 2290 2230 16.19 0 0 0 0
17.4 5600 184.2 2260 2190 16.99 0 0 0 0
18.3 6000 178.2 2190 2140 17.8 0 0 0 0
19.12 6280 171.4 2190 2120 18.7 0 0 0 0
20.03 6560 157.9 2170 2110 19.61 0 0 0 0
20.92 6800 142.1 2160 1990 20.43 0 0 0 0
21.84 7040 154.9 2170 2000 21.44 0 0 0 0
22.64 7200 154.9 2030 2120 22.22 0 0 0 0
23.44 7240 81.2 1170 1810 23.04 0 0 0 0
Many thanks guys!
