Anyone got the coding for adjusting the DRL's when the headlights are on?
Hi Zombie, are you wanting to adjust the DRL's so they are brighter when the headlight is on? If that is what you want to do then here is a tip, whatever value you set for the DRL brightness with dipped headlights I would recommend setting the same value for when indicators are on. If you didn't and the value for the indicators were lower say, then at night when the headlights are on and when you signal the DRLs will dim (you can see by default the values are the same) I made this mistake and found it annoying! lol
Here are the instructions which I made a note off when doing mine initially, I have reverted back to standard settings now though.
Hope this helps
DRL dim Adjustments option in VCDS is:
*Go into [09] Central Electronics
*Go to Secuity Access and enter 31347
*Go into Adaptation
*Then change the channels as follows:
To adjust DRL brightness when Dipped and Side lights are on -
default value = 35
LHS - "(6)-Leuchte2SL VLB-10-Dimmwert AB2"
RHS - "(6)-Leuchte3SL VRB-21-Dimmwert AB3"
To adjust DRL brightness for when Indicators are on -
default value = 35
LHS - "(14)-Leuchte2SL VLB-10-Dimmwert EF2"
RHS - "(14)-Leuchte3SL VRB-21-Dimmwert EF3"
Hi Zombie, are you wanting to adjust the DRL's so they are brighter when the headlight is on? ...
Activation of the fog lights (NSW) and Cornering
The onboard supply control unit, you have the option of the Seat Leon 5F fog lights (NSW) to activate additional as cornering. With active low beam, the respective front fog lamp is thus driven in accordance with steering angle and thus provides additional illumination when turning.
1. Select 09 – Cent. Elect.
2. Select 16 – Security Access
3. Enter Unlock Code 31347 active - Click DO IT! And yes if it brings up other boxes
4. Select 10 -Adaptations
5. From drop down select - (5) Leuchte12NL LB45-lichtfunktion B 12
6. Set Value to Abbiegelicht links active - Click DO IT! And yes if it brings up other boxes
7. Staying on same page select - (5) Leuchte13NL RB45-lichtfunktion B 13
8. Set Value to Abbiegelicht rechts active - Click DO IT! And yes if it brings up other boxes
Why did you revert back to standard btw?
Also, can I just confirm that the 'value' is a percentage? I am pretty sure it is, just wanted to be certain.....
If I enable some things on my 14 reg Leon does that void the warranty?
