Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Having just enabled rear led tail lights to be on at the same time as the front led DRLs, I notice that as a consequence of doing so, the instrument dials/light switch and all the switches are also illuminated, is this normal ?
Leuchte23, 24, 26 and 27 are the tail lights. You must go to one letter (D/G or a letter which has "not active") and set it do "daytime running lights".
No not the carbon FIS as that alters the dispaly between the clocks?
The sports interface HMI displays on the nav and shows g force, oil temp, water temp, boost pressure etc, I think.
It is standard on MY16 Cupras and it comes with the optional dynamic pack on the FR.
Pic here: http://www.seat.com/content/com/web...ls.resizeViewPort.422.image2FileReference.jpg
Which version of VCDS do you use for Leon 5f?
I tried to mod my rear wiper, but I received error response from VCDS when trying to enter STG 09 (Board Network)..
Using VCDS 11.11.2
