Phillips1795
VCDS - How To Guides - MK3 Leon 5F
Ben.
23
South Ayrshire
It was me who had the yellow light turned off on the SEAT Drive Profile button. Trying to find the coding as it was on a german forum when I did it with my mate.
Sorry for the delay.
DEAN0
Old Git
Feb 1, 2006
5,439
Preston - UK
Would be great if you do manage to find it - it really bugs me having the yellow light on at night when driving.
Ben.
23
South Ayrshire
I can't find the coding anywhere, I think it was on MQB-Coding but they appear to have removed their coding options.
I think it's near the ambient lighting adjustment (Door lights Red in all modes) but a different byte. We were flicking through and found it, the option is a rough German translation of 'without function light installed'
Hopefully someone can find it but I'll try keep looking for it.
Luckypants
Extra Large Member
Apr 7, 2015
177
N.E. Wales
I found someone who was able to make some VCDS mods for me.
We got the following done:-
Needle Sweep
Fuel to Fill
Corrected MPG given by computer (was over-reading by 8%)
Rear DRLs
Blower speed indicator.
We couldn't get the door mirror fold on lock to work. Can anyone give me the full instructions to get this enabled? My car is a 2015 model year and almost exactly 12 months old.
john doe
55
Needle Sweep
Fuel to Fill
Rear DRLs
Try this:
Select 09
Function 16
Enter Unlock Code 31347
Function 10
Select (22) access control mode 2 radio Spiegelanklappung
choose ' by look command via remote control key'
Should work after that.
concerned cat
497
Huddersfield UK
Needle Sweep
Fuel to Fill
Rear DRLs
Glad you got sorted!
Luckypants
Extra Large Member
Apr 7, 2015
177
N.E. Wales
Try this:
Select 09
Function 16
Function 10
That is exactly what I have down in my notes, but the guy couldn't find it. Now I have his number, we can have another go when we have more time.
Cheers Cat. :D
FRoSTy
34
Hi
I've just picked up a used 64 plate Leon ST FR 1.4 ACT, and noticed that it does the "needle sweep" thing when turning on the ignition...
Does this mean the previous owner been playing with VCDS?
The car was from a main dealer, and probably an ex staff car, so i'm a bit worried that it may have been modded in other ways - what else should I look for as obvious changes?
who.am.i
Leon FR
Jan 23, 2016
392
30
EU
Yes probably someone was playing with vcds..needle sweep is facory only in audi s and rs
vag familia
vime81
22
Milan
Cheers Cat. :D
Hi, if I don't remember wrong in 2015 model as mine the same code is at number 24 not 22, in this way you should be able to enable it. Let me know.
vime81
22
Milan
I have enabled the mirrors closing without long key button pressure but on 2015 model they reopen when you open the car, it's not possible via VCDS code reopen them only when you turn on the key on the panel? I haven't found solution... thanks!
