P10 GGOT
Hello,
Just after peoples opinion really.
I've currently got a completely standard (or so i th ought) 03 LCR, and yesterday I decided to fit 007p and smooth/ drill airbox. Fitted 007 and found out that it already had an open filter fitted all be it in a home made and very OEM looking casing. Anyway took casing off and after sounding like Darth Vader on Steroids is thought I'd run some logs through VAG COM
Turns out, mass air flow peaked at 171.11 which i work out to roughly be 222BHP?
I've got to be happy with that right, considering its meant to be 210. thats despite the fact it need a service.
Pic's & log to follow, let me know what you think as I'm new to forced induction
Chris
Heatsoak was always a 'concern' you're right, never seen any occurances though........always wondered if it was a 'real world' issue or just a theory :shrug:..........plus the last three summers in the Uk the heat has never been a factor ;)
The key to decent induction was always in how to get a decent airfeed in round the battery.......without relocating the battery it's not a simple solution.....infact even relocating the battery it's tricky.....not sure I ever got a 'good' result in the 3 or 4 solutions I tried
The open filter wasnt in the OEM box, but had had a custom (cylinder) one made and was in that. bolted where OEM box once was. I looked very neat, and wasn't obvious at all
does the diy cover have a cold air feed goint to the inside of it, or an open end? looks very restrictive on airflow to me, no real air feed to the actual filter inside is visible.
It was using the OEM feed to the box, however I removed that when I removed the housing.
TBH it pulled well with the housing on, but it's even better now
I may put it back on and run some logs see if the housing has any effect
Looks like a paint tin/coffee tin sprayed to me.
Nope, its wood.
About 12mm thick MDF at base with a thin sheet wrapped around it. Silver foil and bubble wrap stuck to inside, guessing as some sort of heat shield. Then plastic ring on front .
Pics don't do it justice for what it is and it does look OEMand that it should be there when fitted
I bought a small LCD display a few weeks ago with temp sensor which I'm planning to setup in the car.
Going to put the thermister close to my open cone and put the LCD display at the bottom of my pillar.
Be interesting to see how much the temperature changes inside the engine bay when moving and when stationary in traffic. Obviously temps are going to rise when still but I'm thinking they could drop back down to ambient temp quite quickly.
Also been thinking about modifing the ducting for the side mount intercoolers (I have forge FMIC) to use as a big air scope and feed to the filter
