vibration
villain24
RIPPER
Nov 20, 2006
313
seem to be getting a slight vibration in the steering wheel, when i go on a motorway at speeds of around 70 80mph. The steering wheel isn't vibrating lik when u need your tyres balanced, but i can feel it slightly vibrate when i go up 2 those speeds. Is this normal, anyone else on here have those issues??
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
yup, if the vibration is at a set speed and you get no vibes below or above it then it's probably a wheel that is slightly out of balance
most tyre places will check balancing for free but will charge to correct it
get all 4 looked at as rear wheels cause funny balancing vibes too
Nath.
Jan 1, 2006
8,619
16
yeah I don't see why not
as said before they only charge for correcting the balance not to check it, this is the same with wheel alignment too
If the balance is out and they correct it make sure they use sticky back weights and place the weights on both sides of each wheel (DYNAMIC BALANCING), the oustide weights can normally go just behind the spokes of your alloys, the easy and cheep way is to cheat and only attach weights to the inside edge of the wheel (STATIC BALANCING)
this is ok but if you are picky about the vibration you may find that you will pay them to do it and it will be the same or worse so get them to do the job correctly
good luck
villain24
RIPPER
Nov 20, 2006
313
cheers nath
that was really helpful. So it looks like im asking for the car to be dynamically balanced then.:p
