Volume Control Fooked
Black20VT
I need beer....
Sep 21, 2001
293
Swindon - Wiltshire
Hi all,
For some reason, my volume control on my stereo is shafted. When I turn it up, it jumps down, very often to 0 and I've have to start again. It's getting really frustrating now, as it's sooo difficult to turn up. :censored:
Any idea what it could be? To me it sounds like a dodgy connection, but anyone any idea how to fix it? :think:
Thanks in advance :)
mk1golf_jack
Golf nut
Mar 13, 2007
80
Herts
I have the same problem, i have no idea what it is either, i have found though if i pull it out as im trying to turn it up it works, but it never has a problem when im trying to show someone!
I need to fix mine too, its driving me bonkers!
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
is it really failing though
they are quite temperamental and seem to correct themselves if for example you were to accidentally turn it up too loud. you have to be gentle
Black20VT
I need beer....
Sep 21, 2001
293
Swindon - Wiltshire
It's been like it for about 6 months now. Was fine, but now, being rough or gentle (oohh errr) makes no difference, it's determined to stay at or around 0!
I was wondering if it's the connections?
shaunmc263
on mine to turn the volume up i have to press the plastic just above the volume control then turn it up, then sometimes it just goes down to 0, really annoying..i think mine is a connection problem but just havnt got round to looking at it yet
NowGottaIbizaMk5
375
Beverley
Mine is the same problems as JimYu ... seems to love being set to zero. Even delicate turning of the volume control knob with fingers placed on each side can be useless - especially if you go over a bump at the same time ;-(
So, if it needs cleaning how do we do it folks?
Is it related to the problem with the cd changer not being recognised at random (although someone did say that it might be an earthing problem)?
Is the headunit knackered or repairable then?
Jun 28, 2001
1,533
GTS Intermedia Services Ltd
Unit 36, Woodside Park
Rugby
Warwickshire
CV21 2NP
+44 (0) 1788570088
ttothec
349
Reading
mine does the same... i find turning the volume control in the anti clockwise direction (quieter) about 4-5 full turns, it then works fine for the rest of that day
Essex_Cupra
466
Same problem !
I thought it was because of the dust, if you give it a strong blow all around the volume control it seems to work perfect for a while might just need a good scrub !
Although I would like a perminant alternative without replacing it with a head unit!
