VW Group Lubricants - June'08.
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
VW 009 300 - VW power steering fluid spec.
VW 500.00 - VW spec for multigrade engine oils for petrol engines with SAE 5W-X/10W-X viscosity.
VW 500.00 + 505.00 - Oil meets both VW 500.00 and 505.00 spec.
VW 501.01 - VW spec for petrol engines.
VW 501.14 - Brake fluid with low viscosity, VW 2006>.
VW 502.00 - VW spec, oil for petrol engines. Successor of VW 501.01 & 500.00 spec.
VW 503.00 - Long-life petrol engine oil for VW cars with WIV. Meets ACEA A1, SAE 0W-30 or 5W-30.
VW 503.01 - Special engine oil for some VW petrol engines. SAE 5W-30.
VW 504.00 - Long-life petrol engines with WIV.
VW 505.00 - Passanger car diesel engine oil, minimum performance level CCMC PD-2. Lists viscosities:- SAE 5W-50, 10W-50/60, 15W-40/50, 20W-40/50 requiring 13% max evaporation loss and SAE 5W-30/40, 10W-30/40 requiring 15% max evaporation loss.
VW 505.01 - Special engine oil for VW turbodiesel with pump-injector-unit and for the V8 commonrail turbodiesel engines. Meets ACEA B4 SAE 5W-40 spec.
VW 506.00 - Special long-life engine oil for turbodiesel engines with WIV, viscosity is SAE 0W-30.
VW 506.01 - Special long-life oil for turbodiesel engines with pump-injector-unit with WIV.
VW 507.00 - Long-life diesel engine oil with WIV.
VW B 000 700 A - Special VW approved brake fluid.
VW G 002 000 - Special VW hydraulic fluid for power steering.
VW G 004 000 - Special VW hydraulic fluid for power steering.
VW G 009 317 - VW gear oil for manual & automated 6 speed transmissions.
VW G 052 145 - Special synthetic gear oil, SAE 75W-90.
VW G 052 162 - VW spec for Esso LT 71141. Special ATF with additional friction modifier for some ZF automatic gearboxes (ZF 4HP20, 5HP19, 5HP24, etc).
VW G 052 171 - Gearbox oil SAE 70W-75.
VW G 052 175 - Special fluid for Haldex clutch. Developed by Haldex and Statoil.
VW G 052 178 - Gearbox oil SAE 75W.
VW G 052 180 - Special VW fluid for multitronic CVT.
VW G 052 190 - Special VW fluid for multitronic CVT transmissions and differential, built in one.
VW G 052 300 A2
- Compressor oil.
VW G 052 726 - Gear oil SAE 75W.
VW G 052 798 - Gearbox oil SAE 70W-75.
VW G 052 911 - Audi spec, for gearboxes of FWD cars with longitudinal engines. Meets API GL-5, SAE 75W-90.
VW G 052 990 - Special ATF, for VW automatic transmission and differential built in one.
VW G 055 005 - Special ATF, for VW automatic transmissions and transaxles.
VW G 055 145 - No info available.
VW G 055 162
VW G 055 175
- Special fluid for Haldex-clutch. Developed by Haldex and Statoil.
VW G 11 TL 774-C
- VAG spec engine coolants.
VW G 12 TL 774-D - VW standard antifreeze for use with VW group vehicles. Red in colour - must NOT be mixed with other antifreezes and particular coolant additives which comply with standard TL VW 774B or C (G11) - Blue-Green in colour (which may have been used in earlier VW group vehicles). This standard should NOT be used to top up TL VW 774F (G12 Plus).
VW G 12 TL 774-F - VW standard for antifreeze for use in VW group vehicles, Purple-Lilac colour - can be mixed with TL VW 774D - Red in colour (which may have been used in earlier VE group vehicles).
VW G 50 - Special synthetic gear oil, GL-4+ SAE 75W-90.
VW G 51 - Special synthetic gear oil, SAE 75W-90.
**WIV** - Extended drain periods, 30,000Kms (18,641 Miles) or 2 Years.
This applies to the whole SEAT range but was unsure where to post.
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
API - American Petrolium Institute (Standards in America)
What the API codes mean;
S/C - Petrol and diesel engine oils.
(S indicates 's'park-plug ignition and C indicates 'c'ompression ignition)
The second letter indicates the quality of the oil, the better the 2nd letter the better the oil. At present (05/08/2008) the latest code is SM (spark ignition) and CJ-4 (compression ignition).
Spark Ignition Classifications
'SM' - For all automotive engines presently in use. Introduced in the API service symbol in November 2004.
'SL' - For all automotive engines presently in use. Introduced in the API service symbol in 1998.
'SJ' - For all automotive engines presently in use. Introduced in the API service symbol in 1996.
Obsolete codes; 'SH' (1996), 'SG' (1993), 'SF' (1988), 'SE' (1979), 'SD' (1971), 'SC' (1967), 'SB', 'SA'.
Compression Ignition Classifications
'CJ-4' - Introduced in 2006 for high-speed four-stroke engines. Designed to meet 2007 on-highway exhaust emission standards. CJ-4 oils are compounded for use in all applications with diesel fuels ranging in sulphur content up to 500ppm (0.05% by weight). However, use of these oils with greater than 15ppm sulfur fuel may impact exhaust aftertreatment system durability and/or oil drain intervals. CJ-4 oils are effective at sustaining emission control system durability where particulate filters and other advanced aftertreatment systems are used. CJ-4 oils exceed the performance criteria of CF-4, CG-4, CH-4 and CI-4.
'CI-4' - Introduced in 2002 for high-speed four-stroke engines. Designed to meet 2004 exhaust emission standards implemented in 2002. CI-4 oils are formulated to sustain engine durability where exhaust gas recirculation (EGR) is used and are intented for use with diesel fuels ranging in sulphur content up to 0.5% weight. Can be used in place of CD, CE, CF-4, CG-4 and CH-4.
'CH-4' - Introduced in 1998 for high-speed four-stroke engines. CH-4 oils are specifically designed for use with diesel fuels ranging in sulphur content up to 0.5% weight. Can be used in place of CD, CE, CF-4 and CG-4.
'CG-4' - Introduced in 1995 for high-speed four-stroke engines. CG-4 oils are specifically designed for use with diesel fuels ranging in sulphur content less than 0.5% weight. CG-4 oil needs to be used for engines meeting 1994 emission standards. Can be used in place of CD, CE and CF-4.
'CF-4' - Introduced in 1990 for high-speed four-stroke naturally aspirated and turbo engines. Can be used in place of CD and CE.
'CF-2' - Introduced in 1994 for severe duty, two stroke motorcycle engines. Can be used in place of CD-II.
'CF' - Introduced in 1994 for off-road, indirect-injected and other diesel engines including those using fuel over 0.5% weight sulphur. Can be used in place of CD.
Obsolete codes; 'CE' (1987), 'CD-II' (1987), 'CD' (1955), 'CC' (1961), 'CB' (1949), 'CA' (1940)
ACEA - European Automobile Manufacturers Association (Standards in Europe)
Its members include: BMW, Volkswagen Group, Volvo, Ford, DAF, Renault, Fiat Group, Scania AB, Porsche, Mercedes, PSA Peugeot Citroën, and MAN AG.
What the ACEA codes mean;
A/B - Petrol and diesel engine oils.
(A indicates a petrol engine oil and B is for light duty diesel engines - only this is a complete marketing ploy, A is suitable for B and B is suitable for A ;))
C - Catalyst/Diesel Particulate Filter compatible oils.
The second number indicates the quality of the oil, the better the 2nd number the better the oil. At present (05/08/2008) the latest code is A5/B5.
A1/B1
Oils intended for use in petrol and diesel car and light commercial vehicles specifically capable of using low friction, low viscosity oils with high temperature / high shear characteristics.
A3/B3
For use in high performance petrol and diesel cars and light commercials where extended drain intervals are specified by the vehicle manufacturer and / or for year-round use of low viscosity oils and / or for use in severe operating conditions as defined by the vehicle manufacturer.
A3/B4
For use in high performance petrol and direct injection diesel engines. Also suitable for applications described under B3.
A5/B5
For use at extended oil change intervals in high performance car and light commercial petrol and diesel engines designed for low viscosity oils. As A3/B4 but lowered high temperature/high shear.
C1/C2/C3
For use in high performance car and light commercial petrol and diesel engines, with diesel particulate filter, three-way catalyst and / or requiring low viscosity, low friction, catalyst compatible oils.
JASO - Japan Automobile Manufacturers Association (Standards in Asia)
Its members include: Toyota Motor Corporation, Nissan Motors (formerly Datsun), Honda Motor Co., Ltd, Mitsubishi Motors Corporation (Member of the Mitsubishi Group), Suzuki Motor Corporation, Mazda Motor Corporation (Affiliate of Ford Motor Company – 33.9% ownership), Daihatsu Motor Co., Ltd. (Major shareholder: Toyota – 51.2%, thus a member of the Toyota Group), Hino Motors (Member of the Toyota Group), Subaru (Automotive division of Fuji Heavy Industries — Major shareholder: Toyota – 8.7%, thus a member of the Toyota Group), Isuzu Motor Co., Ltd. (Major shareholders: ITOCHU, Mitsubishi Corporation, Toyota – 5.9%, thus a member of the Toyota Group), UD, or Nissan Diesel Motor Company (Major shareholder: Volvo Group – 13%), Mitsubishi Fuso Truck and Bus Corporation (Major shareholders: DaimlerChrysler – 85%, Mitsubishi Group – 15%), Kawasaki Heavy Industries, Yamaha Motor Company.
OEM - VW Group (For us lot at least)
