One question: Why?
Isnt wastegate chatter really bad for turbos? Its surely much better to relive the wasted pressure of a turbo all in one go than letting it go in chunks?
I'm sure i've read articles on why chatter is bad for the life of the turbo.
I think this is a bit of a myth tbh
Are you sure? When you actually think about what happens when u get chatter the blade in the turbo will be forced to slow down the allowed to spin again then forced to slow down etc...
I don't think the ECU could do anything? It presumably causes back pressure on the turbo. So you will have the active force of the exhaust gasses on one side of the turbo wanting it to spin the "normal" way then the back pressure your causing with chatter trying to make it spin the opposite way. The "Myth" apparently causes excessive shaft play (its the twisting force on the shaft and blades that will cause this over time).
So turbo chatter is out of the question so what's the best dump valve to get?
