Hi, does anyone have info for ajusting washer jets?.they are fan shaped spray pattern & have slits rather than holes,dont want to damage them by poking arround with a screwdriver Thanks.
if you're handy about the house and careful enough with using such a paperclip-tool, you should be able to adjust the fan sprayers without demounting the hood
only the center slit is spraying, avoid poking in there ...
left & right openings are meant to turn the cylinder inside.
