My56 Plate FR with the large MFD (Bluetooth) has a warning for low screen wash. comes up as text warning in main display and then flashes a yellow icon at top of display every ten seconds or so.
Also has cruise light in speedo area which only comes on when you set the cruise.
Has two seat belt warnings, small icon in speedo area and text display in MFD, if you then ignore it as i did last week whilst on a large industrial Estate it starts to bleep at you!
Paul
Hmmm. I've got the Bluetooth option as well so did expect something to appear on the display when the washer bottled was empty - but nothing.
It's more a nice to have than essential, might have another chat with the dealer and see if it's something that can be activated easily.
Speaking of warning lights that dont appear the manual talks about a cruise control warning light to show when the switch is in the on position, neither my car nor one I test drove displayed the light! anyone know if this is like the washer fluid light no longer current??
Mine did the same, so it is going in at some point to have the bulb changed.
No idea if the low washer fluid light works or not. I haven't run out, yet! :D
I might be wrong but I think I read somewhere on here that due to the extra wiring looms needed etc you only get the cruise light, lower washer level etc when you have the bluetooth kit and the larger MFD.
I was told that you only get the Cruise Control light illuminated if you have the large Multi -Function Display. Annoying really, as the symbol is there just lacking a bulb i bet!
Rob
I've got the MFD and I have the Cruise light, my mum doesn't have the MFD and doesn't have the light. It does show in the manual there is a low washer level warning on the MFD I've not run out yet to see it.
