Washers wont work
Tonx
Hi Guys
I have a 2001 leon cupra and the washers stopped working. Front and rear. Fuses are ok! they both went off at the same time . Then while investigating the bottle/motor the rear has now started to work! Any ideas regarding the front one would be appreciated.
Tonx
Tonx
No noise from pump. only whe the rear is working. But I think there may be seperate pumps. Cheers
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
There's only one pump, at the bottom of the reservoir. The other electrical item down there is a level sensor. The pump runs one way to wash windscreen and headlamps (if washers fitted), the other way to wash the rear screen. So the pump isn't earthed, both power lines go back to the switch so that power can be applied either way around.
Sounds to me like you need to look at the stalk switch on the steering column.
SWANSWAY CUPRA Dealership
