Took a day off work today to try to get some jobs done on the car (in daylight). It's an FR TDI.
Planned to change the rear brake discs and pads, change the gearbox oil, clean out the EGR valve and replace the intercooler pipe seals.
Stripped the rear brakes to find none of the 5 different sides of my caliper wind back tool fitted the Leon piston indents. So, everything back together again.
Looked at EGR valve but no way could I see how to get it off the inlet. Top two bolts easy but the third was hiding behind the cooler pipe bolts, themselves almost impossible to touch let alone remove. Another waste of time....
Took off the undertray to find that the gearbox fill/drain plugs use a funny kind of splined fitting (why???) and not the usual allen key, so no-go there either
The only thing I managed to do was replace the IC pipe seals, only to find the red pipe to the turbo was loose at the turbo end so evidently worn and needs replacing (I guess the cause of the low power I posted about previously)
Is it me or are Seat trying to make the cars so hard to work on that there's no choice other than to take them to a dealer???? What a annoying waste of a day's leave!
Just needed to get that off my chest....
