May 31, 2008
1,247
Hi guys, i have a slight problem, after the snow i have been having a problem with water getting in my passenger footwell and the footwell in the passenger seat behind it. I have checked the seals and sunroof but these dont seem to be the problem.
Im not sure whether i bottomed it out on the snow a few weeks ago but its since then in which the problem seems to be occuring.
Any help would be much appreciated, thanks guys :D
have a butchers at your scuttle panel /pollen filter area for the front the back might just be the water seeping across the carpet as its a 3 door isnt it? mine gets water ingress to the boot, but thats mainly do to it not being a completely flush fit since its rear ender.
I know this problem...
İf you removed your interir door panel ( its so easy)... U will see a nylon cloth...
Nylon cloth is adhesive... If you repair adhesive nylon tarp. İt will be ok.
Rain water leaks inside from window wick.
Sorry for my english :)
could be many things, blocked scuttle drains, sunroof drains, door membranes, door seals, boot seal. i know its a bit of a pain in the rear but best thing to do is strip out the carpet and get in with someone running a hose pipe over itkeeping your onions peeled for where its coming in
all sorted ended up my sunroof drainage pipes were blocked, thankin you muchly kyle :)
