Water leak i cant get a full photo.
Jul 27, 2020
10
Hello can anyone advise or may have a photo of what could be leaking. Im going to drain it diwn and fix it but id rather have everything ready than off the road to long.
300bhpdaily
1,246
568
Fan switch on rad. Pull it out should have a rubber O ring on it. Make sure clip is secure properly first.
Jul 27, 2020
10
Thankyou and is that when its drained? Probably a daft question being that its leaking but if i can save draining it and its just a sensor switch it would help immensly
300bhpdaily
1,246
568
The o ring comes with the clip when you buy a new sensor you might be able to buy these separate not sure. You really need to take it out and see why it’s leaking tho first tho.
Jul 27, 2020
10
That is my worry incase its the radiator then im well and truly stuck. I had thought drain it then tigerseal round it.
Jul 27, 2020
10
Hello I left the job till last minute as i usually do ?.
Ive purchased the part, bit of confussion regarding the clip main dealer seems to think there isnt one.
I have a better photo now could i just double check anyone see on the photo if it needs a clip and which is the best way to go about doingbthis is there any risk to radiator damage if done wrong.
300bhpdaily
1,246
568
Hi yea sorry my bad your one isn’t clipped in it’s screwed in by the looks of it. Should be a case of unscrew and refit.
Jul 27, 2020
10
Great thankyou. I may have a prob the plugs quiet stuck and apparently there is a place to put a small screwdriver a bit lile the coil plugs to unclip. Problem is its on the underside. If i undo the thread first for better reach im going to twist the loom will this be ok.
RUM4MO
7,824
1,000
South Scotland
These plugs, maybe pour a kettle of hot water over that plug, then quickly force it in towards the thermal sensor and while keeping it forced in, try to press down on the retainer lug as hard as possible and pull it out. Pressing it in hard initially will relieve some of the load on the retainer wedge caused by the sealing washer. That sensor sealing point, across the VW Group fleet of all ages, has been the source of leaks, have you tried slightly tightening that thermal sensor as a first crack at sorting this - again pour a kettle of hot water over that area first to clean it up and soften the O-ring seal before trying to tighten it a bit.
If you do need to replace this sensor complete with its O-ring seal, try to get organised and quickly swop sensors over to minimum coolant loss, making sure that you use a 50% mix to top the coolant back up to its correct level.
Jul 27, 2020
10
Thankyou for all your help its been realy appreciated. My son got the plug off and when i had the socket in use the sensor wasn't in tight but im glad i took it out and changed it as it had no washer.
Now i look at the new fitted one the washer is very visable.
My engine light is on for a 02 sensor code bank 1. it started 2 days ago so niw on to the next job.?
