flashbsd said:alex..
turned out to be the ECU (that water i noticed today certainly wont haver helped matters!)
Flashy
Mike_IbizaCupra said:Following on from Flashy....I think you should speak to someone who has a standard Cupra ECU or at least has the facility to put their ECU into Stock mode... just to try it out.. see if it is your ECU... who knows... if it runs OK, maybe a DEMO of REVO could be switched on
I have no idea who could help you out though![]()
acidstrato said:bloody hell, your not having any luck? one minute its fine, then its broke, then its fixed, then its broke again
although if it genuinly felt fine after swapping the vac hoses, then id go around them all again just to check one hasnt popped back off and check the dv for leaks if you havent done so already
the ecu is quite extreme but it does get wet and does happen
Mike_IbizaCupra said:Book it in where?
CupraTgirl said:Hhmm someone that has an SPS3?![]()
I am going to try and book it in today
flashbsd said:i am possibly goingt o vag-tech later on today to collect my fixed car, or tommorrow, i will have a chat with them about it for you, save you explaining things.
Nothing wrong with your actuator hun, if you unplug yourMAF its fine, nothing electronic on an actuator, sounds like ryan hit the nail on the head. Good lad! his ran fine with MAF unplugged too,.
