You'd hope so. However, it might not be that clear cut.Surely a warranty fix?
I had condensation in my headlights (both sides). They refused the claim as it "wasn't actually pooling in the light".
The dealer advised me to jet wash the car to try and make it worse so they'd be more convinced.
I hasten to add, this sort of behaviour is not exclusive to Cupra.
BMW tried similar tactics. I had some light paint bubbling starting on one rear wheel arch at 8 years old.
The paintwork is warranted for 10 years. I tried to claim. They measured the pain thickness and said that it was too thin and had therefore been painted so the claim was refused. The car had never been repainted at any point. They disagreed and I had to get it done myself.
If they were telling the truth about the paint, I suspect that it was painted pre PDI as I know that they can suffer damage in transportation as I have a mate who works at DFDS and he unloads imported cars and has seen damage. They also stored them outside in standing water awaiting pickup. Go figure.
I spoke with the service consultant. He said that the vehicle would be inspected and that it would need to stay for a few days. When I first got the vehicle, I had a Headlight Height Adjustment error. The headlight was changed under warranty. I think the vehicle was manufactured with a fault.Surely a warranty fix?
Not just Golf's. My B5.5 Passat had the same issue with the front wings. VW didn't want to know..." caused by stone chip damage".The small print in car manufacturer’s warranties is often their ‘get out of jail free’ card and can significantly limit the value of the warranty to the consumer and paintwork and corrosion warranties seem to be the worst for this. Additionally, there seems to be inconsistency of approach by the car manufacturer to warranty claims; as an example, in the mk5 Golf era VW fitted sponge support blocks between the inner and outer front wings at the 12 o’clock position above the wheel arch in some (all?) models of their cars. Being sponge, these blocks absorbed and retained water which over time caused the top of the wheel arch area of the wing to corrode from the inside out. VW‘s (inconsistent) three pronged approach to warranty claims was to;
I think with paintwork and bodywork warranty issues I’d rather have repairs carried out by a specialist body shop than a dealership paint shop. It might void the paintwork / corrosion warranties, but the standard of work is likely to be better than if done by the dealership paint shop and as said, the warranty may be worth very little because of the small print or the dealers / car manufacturers opinion of warranty coverage.
- replace the front wings on some cars
- repair the affected area(s) on some others
- outright decline of the warranty claim on the remainder
Apologies to @creixcka for going off topic. Hope you get your light bar replaced under warranty without issue ?.
Hi, had the same issue with mine, small cracks all along the tail light, took it to the dealership today and they have ordered me a new tail light and booked me in for a replacement under warranty.First of all hello, when i was closing my trunk i noticed some weird cracks in my light bar and left side light. my car is only 3 month old.View attachment 49029
Mine changed under warranty too, after 1 week it cracked again.Hi, had the same issue with mine, small cracks all along the tail light, took it to the dealership today and they have ordered me a new tail light and booked me in for a replacement under warranty.
Thats not good at all! So did you go back to the dealership?Mine changed under warranty too, after 1 week it cracked again.
I called them. They said they would look at the car when I made another appointment. I met someone on the forum who had the same cracks. He replaced it like I did, but it cracked again, and they didn't replace it a second time.Thats not good at all! So did you go back to the dealership?
Is yours a new shape/model Formentor or the old shape?I called them. They said they would look at the car when I made another appointment. I met someone on the forum who had the same cracks. He replaced it like I did, but it cracked again, and they didn't replace it a second time.
