On the facelift models you adjust the mirror so it's facing down as much as possible and try and get you fingers behind at the top and pull firm but gently the glass and the housing should come out together. Be careful if there heated because there should be two little wires which will be connected.
Then from the inside unclip the cover, looks pretty easy to do.
Ah thanks mate, will have a look at that, mines pre facelift buy hopefully its not too much diff.
Sent from my GT-I9300 using Tapatalk 2
Did a deal on a CR170, hopefully should pick it up in a week or so. Theres a few things to be sorted under warranty and my plate change to be organised too! Excited! :D
Hi,
Just poped my KN filter in.
No direct issues, everything went fine.
However very complex solution to remove/insert panel filter..:confused:
BR
Robert
You put in a K&N panel, or full intake? easy to swap the panel, just a load of screws? :)
I put my K&N panel in last week, I've seen a jump in MPG and the whistle from the turbo when it spools up is amazing! :D
Enjoy!
Enjoy!
Yepp, was the panel filter.
I did not go for the full intake, since i do not want to mess with the engine cover...to old for that :D:D
BR
Robert
Received one of the primer only wing mirror covers off ebay today so got out the carbon wrap.
Started wrapping it, got 99% done but for the life of me I coulnt get it 100% crease free no matter how hard I tried or how much heat I used.
So had a strop, tore the wrap off and threw it in the bin :lol:
Going to get some plastidip and spray them insted. Unsure of what colour.
Matt or gloss black I think or something different like a matt graphite grey
Iv got a couple of gloss black squares i can cut out for ya n try.or you can just practise wrapping :)
Damn you speedy diesels...
You still don't get as good fuel economy as me though, SO HAVE THAT.
Cheers mate,
I'll take you up on the offer :) drop me a PM
I was perfect above the crease in the wing mirror cover, but my problems started when I was continuing below the staight line crease.
I got as far as 90% of it spot on but it was the inside edge and the half moon shape that wouldn't go on right.
Basically you have the straight edge of the crease line, leading to a curve and the half moon bit on the inside edge below the centre crease line.
I couldn't get it all on crease/bubble free. Did my fruit in, which cause me to to have a shouting/swearing fit :lol::D:cry:
