What did you and your MK2 do today?
Shawn-C-87
356
Edinburgh
Ordered this for my baby today, hope it gives a little extra growl? Will let you know when it arrives and is fitted!
Clazzer
429
Stoke on Trent
Managed to curb a wheel on the way to work as one of my female neighbours it seems can only cut corners and not go around them:( !!!
connery-tdi
144
Essex
New discs, pads and tires for the rear today. Plus found out I have a broken spring so might be time to look into lowering it.
STU3Y
1,271
Kent
Just enquired about having a terraclean done to the Cupra, the guy quoted me £156.00!
I didn't think it was that expensive?!
Should only be around 95 ish. It is dependent on vehicle and how much work is required to access the fuel system.
STU3Y
1,271
Kent
Sometimes on petrols they charge up to £30 for an emissions test before and after to show the difference it has made, would be worth checking this wherever you go. I had mine done but I'm a 2.0 TDI, And mechanic said mine was one of the easiest as it literally just involves pulling a hose off and putting one on.
Tfsi_Mike
2,387
Doncaster / Germany (Army)
Used the hangar at work to drop the oil and take the sump off to check the oil pick up pipe.
Probably due to changing the oil at least every 5k the pick up pipe was perfect, Ill probably fit the new one though seeing as its in the boot.
Taking the sump to Alex at AKS on Monday to have a boss welded on so I can fit an oil temp gauge.
when I bring the sump back Ill be putting a new filter on and sticking some Millers Nanodrive cfs in. :)
