Next job is to replace the cam follower. Arrived today so might have ago tomorrow
Sent from my SM-G960F using Tapatalk
Well advised move!
I managed to do mine and I'm a clumsy fool at times. I wish I'd gotten the full new O-ring and bolts kit now, but tbf mine wasn't in that bad a condition so I don't think it'd long been done.
Sent from my Pixel 3 XL using Tapatalk
Reactions: Brimfull
There was a bit of rain today so...whipped the quik detailer out once it dried up....naturally. It’s pretty satisfying with wax on when you can give it a quick going over and it looks as clean as when you spent hours on it.
This is quickly turning into an addiction...
I got like that a few weeks back.
It finished with me polishing the exhaust, which I always thought was a brushed black..... turns out it was chrome all along!!!!
Reactions: Legojon
Whoops! Maybe I’ve got a chrome exhaust hidden away...on second thoughts it probably is just steel as presumed lol
Reactions: SpiderWelsh
Haha. Yeah I meant the chrome coloured tips.
I'm considering an upgrade as mine has the centre section that's screwed apparently.
Do I really want to spend more tho, or wait till it dies?
I'd rather get some PS4s on it instead. All about the corners atm!
Quick maintenance wash using power maxed shampoo and another layer of poor boys natty wax added.
In the last week she has had
1x coat of Auto glym Super Resin Polish
1x coat of Chemical guys jet seal
2x coat of wax
To be continued........
Applied a layer of chemical guys butter wax.
Also give up trying to install a copy of v16 maps and instead reverted back to installing v8 maps.
At least since I upgraded the firmware I now get 7 digit postcode search on my rns510.
Some new tires for the front and prepping for the looming MOT time.
Need to check on the airbox as the garage that corrected the cross threaded fuel pump connector managed to break the airbox mounting on the right so the right hand side is loose but the left is attached OK.
Removed the diverter valve in anticipation that the new one arrives tomorrow. Discovered that the one fitted is the revision D plastic diaphragm type.
Not a bad job to undertake, just not much room to work in.
Yours stayed in one piece but mine fell apart when i took it out lol
It held together well. What revision do you have? I ordered a rev g so interested to see if they preform any different.
Not sure how long this rev d had been on the car but I am convinced I could hear a hiss under acceleration
I have a Rev G in now and had a D in before that had been on the car at least from 2013 until i changed it this year.
I did when I changed mine. But that was going from factory original D at 7ish years old to brand new G. So might just be cause it was new.
Will be interesting to see if I notice any difference. I am convinced I can hear a hissing sound when under heavy acceleration, boost seems to come in a big dose at about 2500-3000rpm and then disappears very quickly.
The rev g diverter valve arrived this morning thanks to Awesome Gti
Well all I can say is that there is certainly a big difference from the rev d that was fitted.
The power delivery is a lot more linear and feels much less aggressive as the boost comes in smoother and stays for alot longer as opposed to coming in one big dolop and then disappearing just as quickly.
I can also now hear the engine more at high revs as the engine note was drowned out by a constant hissing sound.
I even managed to leave my £150 cycle light lodged in some suspension parts and after some very spirited driving was relieved to find it still in place when I got home
