Are these plug&play? What bolts did you use? It would be nice if you could share some part numbers! Tx!
It's plug and play for the most part. Copy paste, from a very interesting GolfMK7 forum post:
Click here to see the topic
Rear lower arm stone guard/aerodynamic trim for Twist-Beam Rear Suspension.
Item No. 17:- 5Q0 501 559 "C" or "D", Stone chip guard for under side of trailing arm left side.
Item No. 17:- 5Q0 501 560 "C" or "D", Stone chip guard for underside of trailing right side.
Item No. 18:- 5Q0 501 561, Stone chip guard for top side of trailing arm left side.
Item No. 18:- 5Q0 501 562, Stone chip guard for top side of trailing arm right side.
8E0 825 267, 8mm spreader rivet. 2 for each side
The rear exhaust tunnel:
For twist beam rear suspension:-
Item No.18:- 5G0 825 206 J, Underbody trim for twist beam, £??.?? (x1)
Item No.19:- N903 350 05, Speed washer, £?.?? (x2)
Item No.20:- N909 591 01, Clip/Speed nut, £0.48 (x1)
Item No.21:- N 038 549 4, Black plastic push rivet A04A, £0.18 (x1)
Item No.22:- N909 747 01, Black wide head T-star screw A04B, £0.17 (x2)
The Golf 8 beam cover:
5WA 501 715 A , no pictures of it, no additional screws/rivets needed.
