This morning I received a notification from the Polish equivalent of eBay about new results in my saved searches. I had just gotten out of bed and was still half asleep, but as soon as I saw a listing titled "LISTWA PROGOWA PRÓG PRAWA + LEWA KPL" (roughly translates to SILL STRIP RIGHT + LEFT SET) for 500 PLN (~€120), it woke me up better than an espresso. Brand-new Aero package side sill trims (5F0071610) complete with all mounting clips. The seller described them as “old stock” so we will see. I can’t wait for them to arrive!
I had my track tyres fitted to spare set of wheels (old rubber worn out) for £18-00 a wheel including new valves and balancing which I did not think was to bad.
Reactions: nd-photo.nl
Hello guys. I would appreciate If anyone can help with aluminium subframe swap.
What bolts should I need? (part number, quantity)
TIA
If you're using the original/OEM arms and existing hardware/mounts, you'll need
2 x WHT006844 (washers) OR a deadset/alignment collar kit
4 x N10785401 (longer subframe bolts)
4 x N91231201 (longer subframe bracket bolts)
Plus the alloy subframe 3Q0199369E
I didn’t go the deadset route as I didn’t want to lose alignment via subframe position, and I’m not adding control arms with adjustable camber etc - otherwise you lose all ability to align anything as the subframe is locked tight. The washers are required for clearance
  • Love
Reactions: Giuseppe Busso
THANKS!
Have you completed the retrofit? You see big difference?
Also, what's the difference between G & E part number?
THANKS!
Not yet - it’s booked in for a couple of weeks time (price of wanting somewhere reputable to do it, they’re super busy!)
G is the older part, afaik 3Q0199369E is the newest revision part - I couldn’t tell you what changed between them though!
