• Hi Guest There will be essential maintenance on the server on Monday 10th November from 5am meaning the website will be offline for a period of time. We will do everything to ensure the downtime is kept to a minimum.
Same as I have my fog lights coded to come on with high beam - I’ve paid for 100% of the lights, I’m going to use 100% of the lights! (When there’s no one around).
I am not however one of those eejits who drives around with fogs and low beams on, that’s just irritating (unless it’s foggy)
  • Love
Reactions: gabz and Mo_86
So do you remember last time I've posted about new Aero sill strips that I've bought? They are in great condition, have complete mounting kit but... they are for 3-door version :ROFLMAO: wheel base of 3D Leon is ~6cm shorter than 5D so I will have to sell them.
Luckily I was able to find set that will fit my Leon ;) they were not as cheap as other ones (1100PLN, ~250€ compared to 500PLN, ~120€) and does not have mounting kit but they are also new.
Probably I will not be able to paint and install them in this year. Painting is sooo expensive nowadays!
Just a quick update, have ordered a rear seat delete kit (this is to replace the rear seat due to roll cage being fitted)
Last week but was waiting for pictures (which have still not come) had the Fluidampr Engine Damper fitted,
Had the front dampers cleaned and new bottom adjustable rings fitted
Brakes had the Bells Cleaned and contact points checked for any galvanic corrosion and/or fretting/cracking. All OK.
Bobbin bolts aligned and torqued accordingly. Calipers were all stripped and cleaned, resealed and Pistons polished before reinstallation with new pads
Had to do a new pad bedding in process for the pads/discs to get best performance and longevity and again to get the best out of the setup I need to do a warning up process on each track day.
This month I will get the coilover socks fitted and have two track days booked for next week to full check out the whole setup.
