Steely wrote
and oh yeah, having a full size spare steel wheel, that still says dont exceed 50mph
If you're talking about a spacesaver spare, its narrower than a full size wheel, so lighter and needs less boot space. The 50mph limitation is due to the tyre. It's also only meant to get you to a tyre
shop - I think it says don't run for more than 50 miles?
If you mean a full-width steel rim taking the same tyre as your alloys (like I have in y Toledo), then it's good for the same speed as your alloys - its just cheaper than a fifth one.
If the spare takes a different tyre (different rim diameter, for instance), then there might be a limitation due to the ABS getting confused by the slightly different overall wheel-and-tyre diameters.
Skint wrote
Also, i'm not sure if its on all the leons, but the cupra has an 'electronic limited slip diff' thats effective up to 25mph. Apparently. What it could do for you? i have no idea..
If one of the front wheels starts spinning under applied power (for instance, one wheel on grass verge, one on tarmac road), the slipping wheel is braked by the ABS system, which transfers power back to the wheel with grip.
It is doing what an LSD does mechanically, but using the ABS sensors and braking system.
gav FR wrote
Another thing no one has mentioned, there is a "boot open" warning light on the dash. I only found out it had this when my boot wasn't properly shut once and spotted the light before I pulled off.
Yep, but in my case the boot was nearly shut and the light kept flashing on briefly during the journey. It was never on long enough for me to work out what the symbol was! Very worrying, until I'd worked that out.
