What engine mounts are people running and feedback please
Rikko
Owner Of The Possesed 1
Dec 19, 2006
214
Grimsby
Guys
Im looking at putting new engine mounts in my LCR but want to know what you guys are running and how your finding them
Rikko
FLK
110
UK, Staffordshire
Running the THS FR3 mounts and I'm very pleased with the results. There's been hardly any increase in vibrations and traction is much better especially in the dry with almost all of the wheelhop now gone. E-mail them as well for a SCN discount code before ordering.
I'm still on standard power but Robdon has these mounts on his Leon, which has been heavily modified. If you check his thread he'll give you a better idea of how they've performed on a more powerful car.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
As above, the THS ones seem to be the better choice just now, unless your looking for more race spec ones, then Vibratecs are the better choice.
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
I'm running the top 2 THS with a very hard powerflex mount in the dogbone.
Drives nice the only vibration is on pull away and its not that bad at all.
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
INA track density mounts with the front bush of the dogbone replaced with the solid super-pro one. Vibrations are noticeable, but not offensive; traction is vastly improved, no more wheel hop at all!!
gazR
CUPRA
Apr 25, 2009
418
Derbyshire
i too am using the THS FR3 mounts and really happy with them. barely any vibration felt in the car and the wheel hop which was really bad on mine with the oem mounts in has now all gone with the THS mounts. good price too with the SCN discount :)
just make sure whoever fits them torques them up to the correct torque settings, or you may suffer the same problem as me with bolts snapped and engine not where its supposed to be :(
8bit
3,401
Aberdeen
I'm thinking about this mod as well, quick question regarding the THS FR3 set - is that all I'd need to buy or do I need more bolts, washers, bushes, anything else too?
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
You are supposed to replace the bolts for new ones although I don't think many people bother.
wayne lcr
bored of it now
Mar 5, 2009
4,548
doncaster
hummm seems like the ths mounts a good so will be looking on geting these mid month.did they take long to come them that have bought these ?
wayne lcr
bored of it now
Mar 5, 2009
4,548
doncaster
so if i order them on a monday they shud be here for the weekend then adam? and can it be done in the day?i remember reading a thread you started adam about doing this
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Get the bolts too, these are going to be torqued and stretched, its bad enough doing this without using old bolts, twitchy bum time.
The bolts are so cheap and the repair so expensive its not worth using the old ones
DannyC87
Mar 4, 2008
3,459
Willie, you don't happen to know off hand the size and pitch of the bolts for the engine side upper mount that bolt into the block do you? I need a helicoil.. :(
RobDon
Pro Detailer
N10209603 - M12 x 1.5mm, 65mm long. 4 of these.
N90596902 - M10 bolts 55mm long. 4 of these.
N10155901 - M8 bolts 20mm long. 2 of these.
These are the OE bolts required when changing both engine mounts. Unless you're using similar high tensile bolts i'd just get new OE bolts.
Dogbone mount bolts:
N10268302 - M8 bolts 45mm long. 2 of.
N90597001 - M10 bolt, 70mm long. 1 of.
N10246603 - M10 bolt, 30mm long. 1 of.
RobDon
Pro Detailer
I'm on the THS mounts and have zero complaints about them. tried the INA street density mounts which fell apart and were awful, caused a blown turbo gasket. Tried the track mounts but they were way too hard. THS mounts are perfect fast road mounts, excellent price too. Vibratechnics mounts are probably very good but they are twice the price of the THS mounts - twice as good ... doubt it.
