Tartan58
Ex Seat Owner!!
Apr 10, 2008
204
Edinburgh
(pic nicked off ebay!)
Guys, what switch goes here ^^
I assume it's something on high spec models only or an option of some sort as mine is an SE and has nothing.
Just wondering as I want to wire in a swithed rear ciggy plug and want an OEM switch for it!
Cheers!
Cheers!
Thanks for the quick replies folks!
Now that I know what to search for I've found some pics of the heated seat switches too, seems the button layout is quite different so don't think that'll work for me.
So I think what I'm after is the Airbag switch, adm013 you said it's the indicator light, is it a switch as well?
Only a light, the switch is key operated, inside the glovebox.
PS : switches for heated seats, come in place of the drink cup holder btw
What do you need a switch for mate?
The switch is inside the Glovebox, you use your key to turn it off or on, the "indicator" is just a refrence if its on or off.
I want to wire in a power socket (ciggy plug) in the back or in the boot that I can switch on and off from up front. Just want it to look as standard as possible hence wanting to use a SEAT switch if possible.
Good suggestion but I've already got a twin ciggy plug thing mounted in there!
...awaits the question why I need so many ciggy plugs...
Close!
I do saftey radio for the Scottish Rally Championship so when I'm marshalling I have:
Radio Set
Sat Nav
Phone
Orange flasher beacon (the one I want switchable)
[edit] damn missed a golden opportunity for a bad pun - should have said "Close but no cigar!":doh:
