get a T20 anti tamper screw bit saves lots of time. by some electrical solvent cleaner from maplins 3.99 . when you go to unplug the sensor from the cable it was really stiff , just pull it you will not break it. i had to pull with some force to get it off. if you are cleaning the housing and the sensor i would still recommend taking the sensor out. spray all over it even in the grooves. wipe over with lint free cloth removing dirt. spray again and wait till sensor drys. as for the housing unscrew bolts from pipe , take clip off pull with small ammount of force it will come out eventually. spray all through the housing on both metal parts. same rule wait till it dry's. then put the housing back and re screw it all back in. then put the maf sensor in last. and re attatch cable/plug. then good to go . just be gentle when cleaning as it is very easy to break i belive.
