What would happen......
beattie17
1,353
Perth
If i fitted a 3" MAF to my car
Current spec is, blueflame turbo bk,forge fmic,forge tip,BMC,forge Split R,APR Stage 2 ecu.
Cheers Mark
Trig Boy
would there not be a problem with it fitting to the tip, seeing as they would be different diameters?? would you not require an s3 tip or summat? :confused:
beattie17
1,353
Perth
trigboy - I wouldnt think so,as jbs use ibiza tip and 3" Maf
DPJ - So it pointless putting it on till ive got bigger turbo etc
Havok316
Boost Junky
Jun 6, 2006
1,220
Weston-super-Mare
There was another post somewhere discussing about the 4 bar FPR and alot of people said its not needed for a stage 2 but recommended for the highest performance gain possible.
Molehill_Mike
Rollin' on 20s
Jan 3, 2005
2,566
Bedfordshire
Around £50 I believe for a 4bar fpr
I think some of the leon R's came with them...
Do a searchy I am sure its been talked of. Also on the mains SCN site there is examples of Morks showing diff between std TIP and uprated TIP.
Mike
