Whats the damage?
artiedtke
Help, was going up the road before and was going to do a u turn in a junction but did not indicate and i pulled right infront of this guy.
What kind of price am i looking at to get the damage repaired. The excess on my insurance is about £500.
The tracking is well out now as he hit my wheel as i was turning.
Any ideas welcome.
Thanks!
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
Pricey. I'd say £400 for wing and bumper at least. Bumper just needs spraying but you'll need a wing. Maybe a splash guard too. Then you've probably smashed the wishbone is he gave your wheel a wack. Might have bent your strut.
Go through insurance. End bill could be £800ish. Depends on what damage has been done to your strut - wishbone - steering rack etc. Want a new wheel and tyre really too. Wheel will be £100ish I'm guessing and tyre will be £70ish?
artiedtke
Right. Thanks for that. The car still drives ok, but the steering wheel is not straight and there is a scraping sound at full lock etc.
Wheres best to get it checked out, normal garage or a body specialist??
Thanks.
Altech
Ibiza PD170
Oct 3, 2007
1,996
London
I actually repaired an Ibiza that had a wheel hit, damage was much worse than your car though.
I'd say wishbone and steering arm would be bent. Possibly damage to the shock and mabye even the driveshaft. Wheel looks like it could be refurbed, tyre looks low on tread anyway so i'd just change it.
Bodywork wise a secondhand wing can be picked up cheap, I think a silver ibiza is being broken on ebay...worth a look. Otherwise Seat charge about £50 for a new one. Bumper will go again just needs a respray.
If i was you i'd get the front wheels off and compair each side to see what parts are damaged or bent. could post some more pics on here aswell, just so you know in the back of your mind whats involved. Then take it to a garage to get an estimate. Personally i'd say worst case your looking at around £700-800 fully repaired with new parts. But you may be able to knock a few hundred off if you source second hand parts
kriso
_______ C U P R A _______
Jan 29, 2007
2,325
Brighton
I dont know if this might be useful -
Front side collision
Deformed bodywork elements:
Mudguards.
Front wheel housing. *
Outer upper sill. *
Front wheel housing reinforcement. *
Front panel.
Front sill. *
Likely deformed bodywork elements:
Front sill. **
Front wheel housing. **
Outer upper sill. **
Front wheel housing upper reinforcement. **
Bodywork centering points for placement on the alignment bed:
Underbody rear reference opening.
Rear securing point for front frame.
Points for checking and control:
Front securing point for front suspension frame.
Front sill reference openings.
Dampers.
* Side of impact
** Side opposite impact
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
got a couple of spare sport alloys like yours for sale if u want 1 matey, talking like next to nothing for one with a tyre.
