Whats the difference between N75 & N75J
Cupra Gsy
200
As title......I no a few people have changed these but why? And whats the difference between them.
Bobby
ian_cupra
ones get a J and the others have different letters :roflmao:
not 100% to be honest, think its how they deal with the boost, have different settings for holding higher boost, i might be wrong and prob am
Feb 25, 2007
1,068
cheshire
Think the standard valve is an F i changed mine for a J and it peaked a couple more psi that the F and possibley holds the boost better, ive had no issues with the J valve what so ever, but depending on what remaps you run you could possibley run into limp mode. It really hit or miss if you see any advantages.
chrisjackson
n75j reacts slower to ecu therfore holding slightly higher boost for longer
however the J version can cause overboost on some mapped cars. mapped cars tend to run better on the h version.
can also cure some of the 1.8t hesitation problems as the standard n75 can be a bit to sensitive and stop boost then allow boost very quickly
i think the standard 1 is F
