You had your RR'ed Neil? Didn't know you were running a JBS04... CC Stg3 map?? :)
Yep running a JBS04 CC stage 3 and had a cast mani on there since aug,ive only had it RR'd at JKM in portsmouth cause jbs rollers seem always to be broken :confused: on JKM's rollers it only produced 266bhp which im a little confused about, and to be honest im not very happy with the whole set up at the moment :(
when mine was low on bhp it was due to not holdind boost high in the revs, would be good see logs of maf and requested/actual boost..
Neil - have you logged the MAF readings on that? 266 BHP doesn't sound right at all :( Was that with the new mani fitted?
Was RR'd with complete stage 3 done, didnt have a 4 bar fpr or fuel pump fitted wasnt needed
Cast mani
3" D/P and cat
Injectors
3" mass housing
70mm jetex
Pro alloy FMIC 50mm core and 63mm pipe run
Cant log it as i havent got vag-com, to be honest it hasnt felt right since it was done, doesnt pop and bang any more like it used to and sounds completly different :confused:
Neil
Cast mani
3" D/P and cat
Injectors
3" mass housing
70mm jetex
Neil
Very strange that you didn't need a pump! I needed it for my K03s, but then again maybe my old pump was knackered.
I'll head over your way when mine is back on the road in December if you like so you can do some logging and also see what my JBS04 is like compared, running very similar mods.
I can drive up your way have alot of free weekends doing nothing, take it out for a spin and see what you think and do some logs at the same time? get another persons opinion on the setup
Want to get to the bottom of this so i can decide what to do, could just be me but with a RR print out of 266 im a little disapointed at the mo :(
Neil
OK mate yeah either is cool with me. If you can wait til early December when mine's back on the road then you can compare for yourself to see how they both feel. Happy to do some logging in the mean time though - just drop me a PM :)
I have looked at the kit danny, if i buy a kit want to get it fitted and mapped closer to home.
It would be a good idea...as ul have it all bar a downpipe..But im not sure if BDM have made a jig for a downpipe...
i reackon if u sold all the map,turbo,downpipe ect ul get around 1,5k for it easy...
Don't sell it in peices just do it as a bolt on kit for the mk3 cupra..sure someone will snap itup..
Sorry i havent replied guys been away with work, and thanks for the help so far. At the moment i wouldnt sell the map as im not sure if this is the problem, i know the turbo is spot on cause its been looked at and the manifold,injectors are brand new D/P is all ok to. everytime i drive it im just not happy with it so decisions decision?
