What's your suspension set up questionnaire.
ReDBull
Every day's a school day.
Nov 21, 2006
2,990
14
Lincoln
Right at some point soon I'm going to be starting the suspension. I've done a few searches and read a few readers rides. However I thought it would be usful to try and get everyones set ups and feed back in one place. Below is a template that can be copyed and pasted. It would be great if you could contribute cheers Paul.:)
Car model and year:
Dampers/springs:
ARB's:
Spacers:
Bushes:
Strut brace's:
Wheel type size:
Tyer type and size:
LSD fitted, if so which?:
Car used for (i.e. road, track etc):
Good points of set up:
Bad points of set up:
If you could start again would you do anything differant? If so what?:
Faisal
UK's 1st Liquid Yello LCR
May 27, 2008
1,439
Most likely at work
Dampers/springs: Weitec coilover kit
Bushes: Powerflex all round
Wheel type size: standard 18"
Tyer type and size: 225/40/18 michelin ps2s
Car used for (i.e. road, track etc): fast road/drag strip
Good points of set up: good grip, tight handling, great for launching
Bad points of set up: harsh over potholes, scrapes over bumps
if i could start over i'd finish it off lol - with an S3 strut brace and neuspeed rear arb.
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
Car model and year: 225 LCR 2005
Dampers/springs: KW V1 Inox
ARB's: Neuspeed 28R/25F
Spacers: None
Strut brace's: None
Wheel type size: Standard LCR 18's
Tyer type and size: Standard LCR 18's
LSD fitted, if so which?: None
Car used for (i.e. road, track etc): Dogging, commuting.
Good points of set up: Looks nice, handles well for a FWD.
Bad points of set up: Undertray R.I.P, traffic jam behind me over speed bumps.
Ronin225
4,647
22
Worcester
Car model and year: 55 LCR
Dampers/springs: Weitec GT Coilovers
ARB's: Neuspeed 25 and 28mm
Spacers: 10mm rear
Bushes: Powerflex throughout also 034 solid subframe bushings waiting to go on
Strut brace's:Front lower, S3 front upper, Hughes rear upper, OMP Integra rear lower
Wheel type size: 18" LCR wheels
Tyer type and size: 225/40/18 Vredestein ultrac sessanta all round
LSD fitted, if so which?: Going 4wd in the near future so N/A
Car used for (i.e. road, track etc): Commuting, fast road, trackdays too
Good points of set up: Very firm and confidence inspiring in bends, zero body roll on day to day driving
Bad points of set up: Sub 20mph can be a bit rough, maybe too stiff for some
If you could start again would you do anything differant? If so what?: Maybe have bought a coilover kit with rebound adjustment for road driving so i can firm it up for trackdays
Also other things that i didnt know where to put were battery relocated to the boot, Larger but lighter front brakes so less unsprung weight
cupra_r_ick
1,072
lcr 04
weitec 40/50 kit
arb standard for now
spacers none
bushes powerflex
strutt braces no
wheel type oz superturismos
tyre mich pilot sport
lsd peloquinn
used for road soon to be track
good point power out of corners with lsd is insane
bad points, bit too much roll due to lack of roll bars
Sep 18, 2009
2,442
Shropshire
Car model and year: 2004 Leon FR TDI 150
ARB's: none
Spacers: 10mm front, 15mm rear
Bushes: standard
Strut brace's: none
Wheel type size: 18x7.5j
Tyer type and size: Toyo Proxy T1R 205/40/18
LSD fitted, if so which?: none
Car used for (i.e. road, track etc): daily
Good points of set up:lower without effecting comfort levels that much
Bad points of set up: any lowering on a TDI puts sump/under tray at risk
If you could start again would you do anything differant? If so what?: run an air setup instead
Dan1720v
1,928
Street, Somerset
Car model and year: '04 225 LCR
Dampers/springs: KW V3's
ARB's: STD Front, Neuspeed 28mm Rear
Spacers: None
Bushes: Superpro Front end.
Strut brace's: S3 Braces Upper and lower
Wheel type size: OEM
Tyer type and size: 225/40/18 Continental Sport contact 5's
LSD fitted, if so which?: None yet
Car used for (i.e. road, track etc): Commuting/Fast road/ Track
Good points of set up: Corner weighted, Made the biggest difference, Corner speeds up by upto 15mph in places, Comfy on a run, and seems to brace up when pressing on. Turn in is phenomenal, running 5' Toe out.
Bad points of set up: Can be a little harch over very rough ground.
Probably polybush the rear aswell
ReDBull
Nov 21, 2006
2,990
14
Lincoln
Cheers for the replys guys. Is your ride a lot harsher now than with the standard suspension?
dday
old bowy
Mar 3, 2008
35
What is the best size wheel spacers to go for if running 8+18" wheel I have been offered a set of 20mm
for £45 but I am not sure about rubbing the arches as the car is lowered 60mm on the rear 50mm on the front.
Redrat
43
Didcot Oxfordshire
Car model and year: LCR 55 plate 2006
Dampers/springs: KW V2
ARB's: Front Golf R32 (23mm) Rear Neuspeed 25mm (on middle setting)
Spacers: PCD 15mm all round
Bushes: Superpro (all bushes: Wishbones, Dog bone- both bushes,rear beam,steering rack & front ARB)
Strut brace's: Front & rear upper: Alloy/ carbon fibre, made by myself, looks awesome and works a treat
Wheel type size: Rota G Force (Graphite) 8.5 x 18
Tyer type and size: Falcon FK452 215-40-18 (slight stretch)
Car used for (i.e. road, track etc): Summer days & weekends. That is if the F...... rain ever stops,lol
Good points of set up: Handles amazingly, awesome stance, but would like to go lower on front but bloody splitter scrapes too much already, tempted to remove it!
Bad points of set up: A bit hard, need to soften the damping, but involves removing the rears to do so, I've been a bit lazy but will do it when the sun shines (if?lol)
If you could start again would you do anything differant? If so what?: I'd love to go Air-ride but too expensive and would compromise handling
Hope this helps mate, good luck & enjoy!!
__________________
filbro
337
Derbyshire
Car model and year: LCR, 2003
Dampers/springs: standard dampers, Spax ssx springs 35mm
ARB's: H&R front and rear
Spacers: n/a
Bushes: standard
Strut brace's: S3
Wheel type size: LCR factory
Tyer type and size: FALKEN FK452 225 40 18 XL
LSD fitted, if so which?: NO
Car used for (i.e. road, track etc): Daily drive
Good points of set up: Springs give comfy ride, no crashing. H&R ARB's tighten up the body roll.
Bad points of set up: Not low enough.......
If you could start again would you do anything differant? If so what?: H&R springs to for extra drop
Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
Car model and year: 03 Lcr
Dampers/springs: AP coiliver
ARB's: 25mm nuespeed front / 28mm white line rear
Spacers: 8mm front 5mm rear
Bushes: few polly bushes on wishbones soon to all be changed
Strut brace's: front strut brace / twin rear braces top Hughes engineering bottom integra dc2 soon to be fully caged
Wheel type size: 18 "rota grid drifts 9.5j all round
Tyer type and size: yokahama Prada spec 2 all round 225/40/18 soon to be changed to 245 ad08s
Car used for (i.e. road, track etc): weekend toy/ track car
Good points of set up: handles good
Bad points of set up: none
If you could start again would you do anything differant? If so what?: get wider tyres from the start
ReDBull
Nov 21, 2006
2,990
14
Lincoln
Cheers for the replys everyone. I thought this thread had died a death. I've just order a pair of Nuespeed ARBs 25mm front and 28mm rear. I'm going to be keeping the standard springs and dampers at the moment as I can't decide what to fit. I dont think I'll ever go on track so compliance in the set up is important. Coilovers seem a popular choice has anyone tried springs and dampers or could recommend any? Thanks.
Sep 18, 2009
2,442
Shropshire
Car model and year: Seat Leon FR TDI 2004
ARB's: standard
Spacers: 15mm rear \ 10mm front
Bushes: standard
Strut brace's: none
Tyer type and size: Toyo Proxy T1 225\40\18
Car used for (i.e. road, track etc): everyday road use
Good points of set up: better handling and lower looks without too much comfort loss
If you could start again would you do anything differant? If so what?: no
