Wheel bearing
leon cupra r
Back in an LCR!
Nov 10, 2009
902
Barnsley
check it is your bearings first! ive had this for a while and had bearings checked by myself + two garages all said theyre fine, still makes the noise!!! worth a check before you blow 100 quid on it!
BEOWULF
I am BEOWULF !!!
Mar 18, 2006
1,186
I AM IN FRONT OF YOU
Did u sort out your problem mate what was it i definitely think mine is a bearing will do the job myself and the bearing cost £33 quid
leon cupra r
Back in an LCR!
Nov 10, 2009
902
Barnsley
No havent got it sorted yet, hoping to get it looked at this week as I have time off work.... As it's not wheel bearing, I'm guessing its something expensive, such as driveshaft/gearbox/clutch as it is speed related, it must be on the final drive somewhere... sounds very much like a wheel bearing though, and gets a bit louder + more grating when cornering so was shocked to find they are all fine!
for the sake of £33 I suppose you may as well give it a go though!
