Wheel hop, which dogbone should I get?
Liam-James
23
Hi guys I have a 2016 FR 2.0 Diesel 184 and I’m experiencing what I believe is wheel hop, sometimes mostly in the damp, if I put my foot down a little to much I get the traction control kick in and really loud banging.
I’ve not had the motor long myself but doing some Googling I’ve read that a dogbone should help to reduce this and also a premium set of tyres, could anyone please recommend me a good dogbone to fit?
I’ve looked at the powerflex lower dogbone mounts but I’m a little confused which version I need whether that be version 1 or 2 any help and advice is much appreciated thanks.
H Rafiq
1,201
497
Do you have a sport mode? What tyres are you using? I’ve found using PS4s and either Cupra or Individual Mode solve the issue for me. I had the front bushes replaced with Powerflex recently as they’re cheaper than stock. Tyres have to be warm too. Mine almost always hops from a standing start.
Woody_72
502
253
Northwest England
Mine used to suffer from bad hopping/banging regardless of tyre choice. I fitted the Powerflex dogbone kit and it almost eliminated it. It does increase NHV in the car but you don't notice it after a while. What engine is yours Liam?
Reactions: adam davies
Liam-James
23
Yer it has economy, normal and sport mode but doesn’t seem to make any difference to the wheels hop.
Liam-James
23
Cheers for the reply mate what engine is your motor? Mines an FR 2016 2 litre TDI 184
Liam-James
23
Same engine then, let me see if I can find the receipt email... I can't :(. Anyhow, this is the part. You just need to have a look at the bush in your car and see which of these you need. IIRC, mine was red if that helps:
Yer that’s the one I’ve looked at buying the red one that says for diesel cars but I’m confused there’s 2 red ones with slightly different product numbers so now I’ve no idea which one I need!
https://powerflexstore.co.uk/seat/l...mk3-5f-150ps-plus-2013-multi-link-pff85-832r/
adam davies
349
153
Get under the car turn your flash on and take a picture of your mount then compare the photographs on powerflex website. I have a 1.8tsi remapped and have had the powerflex bush in for around 20000 miles, it makes a massive difference to wheel hop and traction.
adam davies
349
153
Heres the two different shaped mounts from underneath car.
Liam-James
23
Cheers for the advice mate, gonna get under and have a look then get the correct one ordered and hopefully I see a positive difference with it.
May 2, 2024
Wondering if you figured out which version it was? Getting mine tuned in a couple weeks and might be looking to get one depending on how much wheelhop I get.
Liam-James
23
I bought both fittings for my model, then got underneath and made sure which matched, then fitted it and sent the other back.
Reactions: Ayaan D
May 2, 2024
Cheers, had a look today and I will need version 1. Will probably go for the red one too as it’s being advertised as suitable for the diesel engine.
