GMInsite
155
Ive found some alloys i quite like and the owner says they might rub on the outter arch they are 15x7 et13 with 195/45/15s whats people opinions im around 70-85mm down
ET13 with a 70-85mm drop..... not a chance, the tyres will get shredded by the arches within minutes, and I'd be surprised if you could even get much lock on the fronts when trying to steer.....
The lower the ET, the further out the wheels stick out.
Stand 6.5J wheels are ET35-38, so these 7J ET13 ones will stick out about another 35mm (25mm from the ET, and another ~10mm from the wider rim).
Thanks for the reply :) Im going to get another set of G60s as the wheels in question were fooked
could make them fit...the way of being "euro"
i am gonna be running 7J ET27
and 8J ET14 on rears :D
bit of pokage :D
but you'd most likely need work done, i think i know what wheels they are :p
