yeah i'm gonna get mine from him too. if i go for 5mm on the front will the rear track still be wider than the front?
mate the LCR is 19mm either side wider than the rear....so if you want the rear to be wider you need 200mm and no fronts.....
if you go for the 5mm fronts and 15mm backs then it will be (in theory) 24mm front 15mm back.....
see thread..http://www.seatcupra.net/forums/showthread.php?t=178184&page=2
can i ask how much you paid for them grey 225?.....wanna get mine soon as...
I got them of badger, including 10 longer wheel bolts it came to about £95 plus postage.Even with coilovers and roll bars it gave an increase in handling performance,more than what i thought it would.money well spent in my opinion.
i think if you go further you will be rubbing the outside of the wheel arch, even before lowering.
I won some forge 16 mm spacers yesterday! Just need New bolts now. What's the correct length bolt to have? Standard cupra wheels, is it literally the case of gettin 16 mm longer bolts?
Can anyone confirm for definite that 11mm Forge Hubcentric Spacers fit the rear hubs of a LCR ok? I've heard and read there may be an issue with the hub "lip"
Would be much appreciated
Thanks!
George
