Spellcast
Sorry guys, the Toledo gremblin has been playing in my engine and I dont know where to post this to gain ur collective wisdom.
The car was serviced and MOT'd last week and went thru with no faults. Hubby went to use it to go to work this morning and came in saying a warning light came on. I went out to have a look for him and its the coolant warning light showing its either too low or too warm.... I stuck my head under the bonnet and had a look and sure enough the coolant is waaaaay under the minimum mark. Admittedly I didnt check it last week as I assumed it wud be checked at the MOT so Im a wee bit concerned its vanished so quickly as last time that happened in another car the head gasket went!
Any ideas?
xx
Any ideas?
xx
If so, check the oil filler cap for white gunk which would point towards a head gasket failure. Check the bottom of the radiator at the drivers side for any signs of leakage as it's a common failure point.
