Which engine oil?
Lancashire Lad
381
28
Penwortham
www.seatcupra.net
Hi all, my check oil level warning came on(first time).
I embarrassed to say I don't which is the correct oil. Its leon fr 184 diesel. I have a bottle of 5w-30 in the garage from my last car. Is that the right one?
caz95
45
17
Should be fine yeah castrol is just the recommended one think I used Mobil last time I topped mine up
Unizz
182
75
Hi mate I have the exact same car
And I put nothing but this, its long life and works a charm. Don't put any other **** in and continually top it up don't let the warning come up again.
Hope it helps
Castrol 15668E EDGE 5W-30 LL Engine Oil, 4L - Gold https://www.amazon.co.uk/dp/B011KRAGH8/ref=cm_sw_r_cp_apa_i_Moc-Cb3S2Z2VS
Regards
Sent from my ONE A2003 using Tapatalk
Lancashire Lad
381
28
Penwortham
www.seatcupra.net
Laurbach
49
24
Does anyone know if the new Cupra with gpf needs a specific oil, or just the same as non gpf engines? The booklet says about diesels with dpf but doesn't mention anything about the petrol?? :think:
KXL
KXL
Dec 15, 2016
1,579
195
London, UK
Hope it helps
Regards
This exactly, I had this very oil in my car from factory, went for the first service after 21 months, thinking, surely the new oil would make it better, or get more mpg. The new non-long life oil (according to Seat, this was Texaco oil and not Castrol) and I felt the engine was worse, and trip PC showed worse mpg right after, and consequently after till I returned the car.
Unizz
182
75
Worse mpg on the Castrol oil I posted?
KXL
KXL
Dec 15, 2016
1,579
195
London, UK
No no, car came on Castrol Edge Professional oil, at the first service they changed the oil to Texaco branded. One would assume, as the oil is new, should give better performance or mpg compared to the old 20+ months oil. But no, it was 4-5 mpg down with the new Texaco oil. So for me, it's thumbs up for Castrol due to this..
Unizz
182
75
Ahhh it's not often im right lol!
Yeah I only use that oil too
LouG
1,319
481
Nelson, New Zealand
I can't see oil alone accounting for a 4 - 5 mpg reduction, unless it was 140 grade gear oil.
Did you do a mileage calculation over several tanks, or just rely on the computer readout?
