so i can just fill her up and she will learn
LC (apart from AUQ) and LCR are recommended to use 98 RON fuel out of the box. Lower octane rated fuel will work, but the knock sensors will retard the ignition timing, reducing both power output and fuel economy.
The ECU needs a couple of tanks to detect that the fuel quality has changed and make adjustments. You won't see a difference as soon as you change fuel, and even one tank isn't enough.
Remapping almost always increases the tendency to pre-ignition and so needs higher octane petrol.
In a forced-induction engine, best fuel economy is not gained by keeping off the boost. In very general terms, best fuel economy is got by keeping in as high a gear as possible and as close to the torque peak as possible. Torque peak comes after the turbo comes on song to increase the boost. The turbo increases the engines efficiency by improving the compression ratio, so on-turbo is always going to be better than off-turbo at the low rev end.
maybe it just does a throttle body reset?
A proper TB reset can ONLY be done via VAG-COM and not battery disconnect.![]()
Yep know there is more than just VAG-Com was just using it as an example to get across fact that battery wouldn't reset TB. Its a common misconecption that's all and seems to get bounded around alot....
Just trying to help.![]()
sorry mate read back my post and realised it maybe sounds rude, was going for tongue in cheek
iv being doing searching though and other than people making it quite clear that disconnecting the battery does not reset the TB i cant find an explination as to why the car feels/drives differently.
if anyone knows ...
in the meantime original poster looks like youl just have to run a tank or 2 before you see any benefits![]()
I have a mapped LCR 225 and I do notice a difference between 95 and 99 now, almost can't explain but it feels a bit odd like its struggling to open up, so Tesco or V-Power for me.
I drive 19 miles each way to work, through speccs 50mph on the M25 and then M4, and cruising in 6th I regularly see 40mpg daily.
And all this talk about cheap shitty fuel etc... I used to work for Total head office in the fuel department, they ALL buy their fuel from the oil depot and then take it to the forecourts, tesco's etc don't actually have the ability or technical know-how to alter fuel they have, so tesco 95 / bp / shell they are the same fuel, it's all psychological which can be very convincing.
resetting ecu will clear any parameters the ecu has learned that may be not right, i.e you may have a slight running issue the ecu has picked up, resetting clears this thus making the car feel better, or say if you have been doing lots of town driving the adaptive ecu will learn this, resetting and doing out of town a road/b road thrash the ecu will relearn this and alter parameters accordingly to the style of driving your doing whivh will again make it feel better.
but as an adaptive ecu the me7 will learn values again if you re do town driving for example.
Whats different about the AUQ engine's, only asking as 90% of LC's have this engine.
