Aug 17, 2021
9
Morning
I am considering downsizing to 18” O.Z Ultraleggeras on my ST 280.
I’ve found on this forum I need 5x112 ET45 so that’s no problem.
I also know I need 75-57.1 spigot rings so that’s all good too.
From reading around though I’m still not sure which wheel bolts I would need. Apparently standard bolts aren’t long enough.
Any help would be appreciated.
Many thanks
Its not that the standard bolts aren't long enough, its that they're the wrong shape.
Standard bolts are radius..
OZ wheels will need tapered bolts.
Most places that sell a wheel package will include a fitment package of the relevant spigot rings and bolts suitable for the car.
Adding spacers needs longer bolts due to it adding the extra offset with the gap. The greater offset of the OZ wheels will be because of the shape of the wheel not the thickness if the hub section :)
Reactions: LE90 and SRGTD
Thank you. After reading your reply I contacted the supplier and they said if I provide them with car details they will supply the bolts and rings.
Can you tell I’ve not ordered wheels online before?
Thanks again
Reactions: Damo H
Thanks again
Everyone has to have a first time sometime :)
