edmong
GHE Tuning
Aug 15, 2007
567
Plymouth, Devon
Hi Guy's, I have tried searching but could not find anything like this.
Once the engine has warmed up and I have driven a fare distance and reach my destination, the ignition is switched off and then this horrible whining noise comes from the engine bay, almost like a pump running. Like I said the engine is off, no power, and its definately not the fans. Any ideas?
Gareth
Run-on cooling pump ;)
Runs for about ten mins after shutdown to keep coolant circulating through the block and turbo. You should be able to see it at the timing belt end of the radiator :)
