rs20
62
STOKE
Hi. I brought a y reg leon cupra yesterday. Want an atmospheric dump valve despite the loss of power etc etc.
Does any one know a company that sells them, and how well they work.
I've searched the usual forge, bailey etc and they only do recirculating.
Please help
Please help
But have you searched these forums?
Dump Valve
I'm assuming that there are adverse effects to this mod then? and your not fans of the noise
We are not fans of people who don;t use the search function.......this question gets asked weekly
the full answer is that they don;t work and to borrow some text from Max Torque
"No rhime or reason"
But:
(and concentrate, here comes the science bit!)
A modern engine management system, ie the Bosch Me unit fitted to 1.8T's has "adaptive" learning on the fuel, ignition and airflow side.
Because Me is a Torque based structure it's calculation of engine torque verses driver demand is critical to the driveability of the car and it's performance / durability.
When you fit a "leak" in the intake system (open circuit valve) the original calibration of the MAF sensor to manifold and cylinder filling modeling will not corespond. However due to the 20% allowance in the long term adaptive values the ECU will relearn you engine and "leak"
At idle the inlet model calculated airflow will exceed the MAF meters measured output, and depending on the state of your particular components - ie MAF ageing / contamination, throttle plate leakage, Fuel tank purge vapour concentration this may, or may not push the adaptive to it's 20% limit. If it hits the limit the ME unit will run in FMEM mode (Failure mode and effects management) causing reduced system efficiency. The Me unit will use the switching signal from the lambda sensor to return fuelling to lambda 1, storing the correction as a map agaisnt airflow. and add this correction to the fueling calc when operating at non closed loop conditions, ie WOT, fuel injector reenstatment (after overrun shut off, traction control intervention etc.) Now depending on how you drive and how sensative you are this may or may not be felt by the driver during certain manovevers. The throttle plate position will also learn the new airflow to maintain control of idle speed, but you may notice poor engine load rejection, ie turn on the aircon and the engine speed varries etc. or engine speed flares on starts or when operating PAS when parking.
However in all cases this will result in "incorrect" fueling. Now by "incorrect" i mean, not as the manufacturer intended. A post MAF leak will cause rich operation initially, but the adaptives will pull fuel out and become negative. This tends to cause a rich to lean spike on tip outs and other throttle transient. Now it is extremely diffucult for an untrained observer to spot these effects as they occur mainly on throttle transients, when the average drive may not notice. Therefore you could say "why do i care?". Well, any AFR excursion from the intended fuelling set by the manufacturer will result in non-standard engine operation. because of the adaptives this is unlikely to cause immediate engine problems, but over the course of time will change things like catalyst ageing, exhaust and turbo charger valve durability etc. Manufactures spend millions accruing miles on development fleets so hopefully the customers don't get landed with big bills as time goes on, and with most modern cars life'd at 150k miles (min design life) this is a big task.
It is unlikely that this will result in any performance loss, as at WOT the system is open loop, but you may see the result of an open circuit valve oas over fueling on gear changes etc. (a tell tail puff of black smoke is what you can see, a 1200 degC Catalyst is what you can't see, as excess fuel when injection reenstates and excess air from overrun shut off period combine in cat)
Now as you can see this is a seriously complicated subject and i haven't even mentioned the dreaded EOBD or OBDII words yet. Typically Bosch Me units have approximately 9000 calibratable parameters (constants, maps etc) and an engine calibration program will take a team of 8 calibration engineers 18 months to do the basic mapping and OBD validation. These days it's no problem to do the basic fuel and spark mapping, maybe 4 weeks on a midlimit engine on a dyno, but the diagnostics and emmisions devs takes years.
Moral or the story, before you start playing with something you don't understand, find someone who does!(And not just thinks they do!)
(for anyone thinking, "hey what makes me such an "expert" on this subject?" then i'd better mention the last 10 years i've spent as a senior calibration engineer at Cosworth and Prodrive!)
Cheers for that. I had searched and read about the engines response to the 'leak' but thought maybe there was a way around it - like a stealth FX BOV which can be screwed down to effectively become re-circulating , and opened up on weekends etc. I have heard from non-cupra owners that you can adjust the level of 'dump' to compromise with the ecu
Thanks for your replies anyway.
Lots of people have tried for a long time, sooner or later the car throws fault codes and then your going to be going slower (not ideal for a tuning part)....the fault codes may appear in 1 day or 1 year luck of the draw.
It's your car though :shrug:
Or rip out the ECU, bypass the MAF, fit a BoV...works but not exactly ideal and very expensive....
cheers for the info. don't want to knacker it after 1 day. i'll hang my head out of the window and make the noise my self - it will be alot cheaper as well!
mine is almost embarrsingly loud now with the stock DV and carbonio :hide:
as everyone said its not the noise tht people dont like it our engines goin tits up tht we dont like fit the cold air induction and the forge 007p and ull sound like darth vader, and dont try the bov like GFB or anything like tht they "do work" but make ur car very un-responcive and fell jolty wen u change gear ie comon off boost
