Got my new oem bushes the other day and decided this morning to fit them, (or try) so started at lunchtime, dont have luxury of ramps so got car up on axle stands, released the shock absorber and took out spring and then undone the axle bolt, internal of old bush fell out, rest was a complete pain, might aswell of been welded in. Had to hacksaw the outer layer and i snapped two screwdrivers whilst prying the old steel shell out, cleaned inside and thought lets go and lubed it up with some washing up liquid (all i had) and would it buggery go in, not even a mm, so borrowed a threaded bar me mate used on my mums astra, and a old cam wheel and some washers and nuts, so then lined everything up and away i go, got it about 2 n a bit inches in and it wouldnt move any further started pushing nuts off the threaded bar, so i got stressed and hit it a few times with a bashing stick, unfortunately all this did was crack the outer lip of the bush, so i gave up and thought that it should be in enough to line it up and allow it to move further in as the car is being driven. Even that was a pain in the rear end, but got it back in and all rebuilt car is still clunking but i think thats the rear shockers,
Main reason for my sob story is i spent 6 hours on the O/S bush and havnt touched N/S yet, i think i should be able to remove the N/S quicker than before but i still have doubts on fitting new one, obviously i need to a new threaded bar and some new nuts but does anyone have any advice on getting it in better than i have done?
