Why is my idle at 2000rpm after Spraying in Carb cleaner
Mk2Ibiza
232
Middlesex
Hi guys... Been a while again.
Sprayed some carb cleaner straight into the throttle body of my 1.4 this afternoon. Got rid of all the dirt and everything.
Took the car for a spin and it seems to stick at 2000rpm for about 5-7 seconds before dropping to around 1000rpm.
However if i rev the car at a standstill it immediately drops to the normal idle which is around 1000rpm.
What are the chances of me messing something up spraying carb cleaner down the throttle body.
All ideas welcome and any fault finding tips.
Big-Pete
Always on the Limit
Aug 8, 2010
2,969
nah youll be fine as soon as all the cleaner has worked its way through.
best bet grab a rag and give it all a damn good clean out(inside the TB etc) and check your vac lines arnt loose!
Mk2Ibiza
232
Middlesex
Cheers buddy. Just wanted to make sure all was ok. As long as you guys say its normal to be doing that, then its all good with me.
