Widest wheels / Arch work.
Poko
82
Hi all,
I am looking to fit to my car (Pre FL cupra) wider tires.
the size i am interested in is 255X35X18 , fitted over 18X8.5 ET ~45
I know that in the GTi this is possible but marginal , but i have no clue about the Leon.
does anyone know if that will fit (at around 2 degrees camber) ?
as a second option , if i can't make that fit i will consider some arch work or a wide arch body kit (not too aggressive). does anyone know any (experience) ? i have seen the JE wide arch kit but that doesn't fit cupra.
thanks in advance.
Jon TDI
Eat My Soot!!
Apr 28, 2003
1,518
Round the twist.
I know that the wheels will fit, as I have 8.5 x 18 ET45 for summer use. The tyres are 225/40 R18.
255/35 R18 will have about the same rolling diameter, but may have issues with the arches & will be a firmer ride (less sidewall).
predo
Newbie
Dec 26, 2005
421
Edinburgh
what, using 255 tyres? I havent tried it personally but I'd be surprised if you couldn't feel the difference even from same size 18" 225 tyres... its 3cm difference!!!
Poko
82
i will be putting down 450+ hp , so no problem with performance , i need the extra traction.
also will be running high camber, so on a straight line it will not be "wider" than 225's.
as for shoulder height , it is around the same as 225/40 - 90mm in 225's compared to 89.25 in 255's.
