been offered a set of 2 piece discs for the rear of my lcr cheap, will they fit, what is needed if so, i know they will fit a tt and r32 but not sure about lcr????
They look good mate,doesnt tt run same rear brake set up as LCR,so if they fit a tt then they should fit,but rears dont do much,id be a bit worried about increasing rear brake performance by alot,it may increase chance of locking rears up and make rear end feel abit unstable.
Ive you run motul CBF600 racing fluid and DS2500 pads and the 330x28 big brake conversion like the one im upgrading to soon as supplied by Bill at Badger 5 then these rear discs should be ok as the front has been upgraded to be quite superior to the std ones. As im lead to believe its not the Brembos on the LCR it the std discs and pads that are poor. Afterall Brembo is probably one of the best brake caliper manufactures ever.
Rikko
then the ABS kicks in - but much earlier than it should
using the handbrake obviously yer it would,but there is no increase in brake pressure to the rear via the master or abs yer the disc size is greater but it wouldnt lock up if your still running abs
