I thought the mk4 golfs block was different - thus their FMICs wont fit an LC. Same turbo - different application, and didnt think it was the k03s, thought its just the k03. (dont they only make 150bhp?!).
Id say get a forge tip - omg love forge so much right now, AMAZING customer support yada yada yada :D
Thanks guy's,
Answer I got from UKMKIV:
It depends what sort of messing around you want to do? The end of a K03s and k03 difference is 1mm so the turbo end will fit. The MaF end is also the same. The problem that you will have is that the DV and the breather pipes from the crankcase on the AGU are in the opposite location so you will need to extend the breather pipe to make it fit. The DV pipe has enough flex to move it to the new location. You will also need to block off the extra nipple below the MAF as the AGU engines do not have that VAC source.
So its not exactly a straight for but can be made to fit.
Lol this is good to know - and DAMN IT!!! I was looking at a cheap as chips forge FMIC for a mk4 but spoke to forge about it and all the pipe work was different apparently :( confirmed this with other people! grrr! Owel!
So in hindsight a mk4 golf tip and fmic will "fit" our cars!
:) good to know!
How about the new shape beetle then - any bits we can pilliage!?!
:) good to know!
The crash bar for the golf is different I believe but the pipe run is the same on most of the other kits.
The TIPS fit ko3 and KO3s cars but as said you might have to block off one of the holes.
I dont think people understood the question the original poster asked if the TIP will fit from a AUQ to a AGU golf. The anser to the question is yes but will require some fettling and that Uk-mkivs post is bang on with the righ info as you need to reverese the breather pipe and diverter valve and block of the lower nipple.
The FMIC wont fit from a golf to a Leon as the crash bar and bumper are different it can be made to fit but alot of fiddling again. The Leon has more room behind the bumper than the golf so it would be difficult to go from a LEON to a golf but the other way round is possible just alot of aggro plus the mountings for them are different for the cooler.
That maybe the case with the Forge FMIC kit but the Toyo Golf and Leon kits are the same [golf one may not have map sensor bracket depending on year]
