will RS6 wheels fit??
Pacey
258
Northants
Hi again need your help again!
Will RS6 wheels from a 58 plate fit my cupra tdi?? If not what will I need to do? They are 5x112
Thanks in advance
Pacey
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
your leon is 5x100 pcd, 57.1mm bore, et35 offset. You could get adaptors to convert from 5x112 to 5x100 but this would lead to a increased offset of a minimum of 15-20mm. If you can find out what offset the wheels you are looking at are we'll be able to help more :)
DannyC87
Mar 4, 2008
3,459
well that gives you 8mm of room for adaptors. the minimum thickness adaptor I can find is 20mm, so your wheels would stick out 12mm further either side than they currently do, you could probably get away with this as I run 15mm spacers on my LCR. the major downside is the adaptors are £147 inc vat from DPM!
